Hollister Aug 9, 2009
Started by jrock, August 09, 2009, 10:32:19 PM
jrock
A few of us met up though more RSVP'ed  :slap:. Place was fairly empty, it was super fun.  More pics to come.
Wermz84
I had a great time, it was good wheeling with everyone again.  :beerchug:
I like to Drive!
Slolyfe
Good times! Here is what I came home to. A broken Chromoly short-side inner. The problem is I cant get the other half out cause it broke in the middle! Longfields here i come.
You'll never take me alive
Steve_925
UA 342
STEAMFITTERS
Slolyfe
Wermz84
I like to Drive!
jrock
jrock
It broke here:
TIMS89CRAWLER
thats exactly how i broke my last one was just idling up a rock in reverse and SNAP! I am glad I finally got some longs!
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
Slolyfe
Quote from: TIMS89CRAWLER on August 10, 2009, 10:09:43 AM
Ordered longs 10 min ago! and no warranty on the axle since Alloy changed owners.
TIMS89CRAWLER
well that blows they wont cover it under warranty oh well at least ya got some longs coming... you get the 30's?
www.choptechfab.com
CHECK THE BUILD
Slolyfe
Quote from: TIMS89CRAWLER on August 10, 2009, 10:41:07 AM
Oh yea!   :thumbs:
82juguete
How much were the longs all said and done, if you dont mind me askin?  Did you get the chromoly hub gears too?  Reason i ask is I've never broken a birf, but worrying about it has me on pins and needles every wheelin trip.  I know its only a matter of time and i want to start savin now!  Thanks
zukjunkie13
Quote from: slolyfe on August 10, 2009, 12:54:16 AM
there is a trick that most of the time works (may take a couple trys.) get a pvc pipe that is about the same diameter as your shaft and run your wirefeed welder wire on the inside of the pipe, and once it touches the shaft the wire will be stuck on it and you can pull it out. like i siad it takes a couple trys.
or
you can get a peice of 1 inch flat stock and and grind one end to about 1/2 inch about 4 inches long and stick it in through the opposite side and get it through the arb, and tap it with a hammer. that usually works for me when i had to do it. if you want you could swing by my place and pick the one i made up and borrow it. cause it works really good.
Life's journy is NOT about arriving at the grave peacefully in a well-preserved body, but rather to skid in sideways, worn out and beaten, shoutin HOLY Sh** what a ride!!!
crawlinforcrohns.org
Slolyfe
Quote from: zukjunkie13 on August 10, 2009, 09:16:00 PM
or
Great advice! I pulled the other side out and was going to try to tap it through. but if that doesnt work I will go with the PVC thanks bro!
zukjunkie13
Quote from: slolyfe on August 10, 2009, 10:01:58 PM
No prob! glad i could help. ive done the tapin one on rear axles alot. so it should work
zukjunkie13
oh one more thing. i know you toyota guys like to back the knuckle full of grease. but you dont need to do that. it just makes for a mess when you have to fix something, all you need to do is pack the birf. thats all i have done for 6years on my grey zuk, and i have never had a problem. like i said it makes for too big a mess and it really doesnt do anything.
8Snaces
Wermz..ur truck is coming along good. Glad to see it on the trails. Im really diggin the cage on that yellow first gen. Very kewl. Looks like it was a great trip.
1st gen yota truck. 37x12.5x15. 5spd dual cases, chevy springs in rear, toyota rears springs in front. Long bed....the list never ends..
Dont try to shift into 6th when u've only got a 5spd! Rubberside down doesnt always mean rite side up!
