click? click? start
Started by toyodaaddict, June 29, 2009, 10:05:54 PM
toyodaaddict
i just got back from a good evening of wheelin,first run since new T chain and head gasket.everything went great EXCEPT....for the longest time when ever id go wheelin and turn off my truck click click start scared the crap outa me every time so i got a new starter and thought the problem was fixed,well tonight click click click click click start. in the past the truck will start fine the next day and does not do this while DD any ideas?
      84 toy 22r
90% of "new" parts store alternators are garbage
should have kept and rebuilt your old one
check battery cables and the ign switch
Cheesemaker
Mine has done this a couple of time, but not enough for me to worry about.  But it always starts.
Tallchevy
My bro-in-law had a 4Runner that did that when he got it. He changed the starter & battery & still had the same problem. I found that the guy that rebuilt the engine had put the ground cable on the frame side of the motor mount. I moved the ground to the block where it belongs & now it starts everytime.  :crossed:
87 4Runner redo
toyodaaddict
ok ive checked battery cables,starter conections and grounds they all look good.ill have to look into how to test my ignition switch.
MiniSimp
ROKTOY829
Check your ground strap from the motor to the cab if you don't have one make one and try that.
skyscraper
I had the same problem....everyone told me the same thing.  Check the cables.  So i looked at them and they were all there, so i figured they werent the problem.  Replaced the starter and still had the same problem.  It ended up that the pos. cable wasnt tight in the battery post clamp.  So even though it looked good, it wasnt.
MiniSimp
Oh, and on my 4runner (doing the same thing) I loosened, greased, and re-torqued the cables on the starter and now it works cherry every time. Forgot about that.
skyscraper
Ya the dielectric grease is a good idea
junya92toy
Mine just would click once, replaced the contacts, works perfect now
brainlessfool
if ALL elas checks out it's more than liky the contacts in the starter.
Steve_925
Quote from: brainlessfool on June 30, 2009, 05:26:20 PM
x2
i had the same problem with my old 4runner, but my problem got worce and worce. i figured it was the brushes not makeing contact with the com. tore the truck apart before i ever figured it out. try spraying some brake clean in the starter, might clean it out
UA 342
STEAMFITTERS
Cheesemaker
What size of battery cables you got?
Get rid of those factory ones.  And get some aftermarket heavy gauge wires.  Or have some made out of welding wire.  Make sure the wire is covered by insulation or sealed.  Cause if they get corrosion in the wires, then you loose alot of conductivity of the wire.
X3, I've pulled more than a few *rebuilt* starters off the shelf, installed them and got the clicky click.  Definately check all connections just like everybody said, corrosion is a dirty little pregnant dog that doesn't play fair.  You'd be surprised how little it takes in an otherwise good system to cause non-starting issues!
toyodaaddict
thanks guys, i appreciate all your suggestions.if the part store starters are crap can i still rebuild one to quality?and while searching pirate4x4 i found alot of info on instaling a relay into the system to make up for a weak ignition i believe. is that a good way to go?
Snowtoy
Yes the relay will work, the Toyota Supra community does the same thing.  I wouldn't bother with it unless you know everything else is working properly.
As mentioned "New" after market starters can be bad, so there is no guarantee that your new one is actually good.  You can pick up an oem starter from a parts yard and rebuild it yourself, providing you can find all of the parts.  The contacts are easy to come by, but worn contacts aren't always the issue w/starters going bad.
True, the ring on the plunger often gets too worn to make solid contact with the contacts.  I went to toyota and was told you couldn't get a replacement plunger, then called my brother at a lithia toyota and he found it pretty easilly.  I suggest updating to the Nippon Denso gear reduction starter if you have the big, cumbersome old style.  They're easy to find parts for and are used on a ton of different apps/brands.
*FFC*
Quote from: MiniSimp on June 30, 2009, 01:51:21 PM
Battery cables. Ground.
:werd: Make sure your battery cables are not corroded, make sure all connections are strong and clean.
I have the same issue in my rig and it's been going since I got it. The clean battery terminals/cables help, but the only thing that'll fix it I think is a new starter. Did you try banging on the starter with a hammer? :disturbed: That works for me (sometimes).
Snowtoy
^^That is usually a sign that the contacts are gone.  Check 4Crawler.com for new contacts, you can order larger ones for a larger contact patch.  Should be able to get 2 shipped for about $15.
Quote from: toyodaaddict on July 02, 2009, 06:03:37 PM
I was going to mention this to you, but you've found it. This is a common problem with Toyota's as they get older. I have used aux. light relays to fix this problem on both Toys and Sammi's since their systems are very similar.
i recently pressure washed my starter, and though if i let it sit to dry out, that it would be fine.... well, i ended up killing it, as tsome water got into it, and rusted, so it siezed up
tortis
I hooked up an aux. relay for my starter after replacing contacts.  Everything else was fine.  Since the installation of the relay my starter probs are over.
