Author Topic: tranny swap  (Read 1228 times)
4x4Haze
  • Turtle Points: 7
  • Male Posts: 337
  • Member since Feb '07
tranny swap
« on: Jun 11, 2009, 12:25:05 AM »
so i think my tranny is bad, its the stock 5 speed out of my 95 runner. so the question is can i use the tranny from an 02 tacoma that came off a 3.4, my roommate did the 3.4 swap and now weve got the tranny sittin out there with less than 50,000 miles on it. I saw the two are different lengths but it looks like if i can swap out the bell housing it might be the same. can this be done? and if so are there any major modifications i need to do???? any input would be appreciated  :beerchug:
A jumper cable walks into a bar. The bartender says, "I'll serve you, but dont start anything."
Billy_Goat
  • Member since Jun '09
Re: tranny swap
« Reply #1 on: Jun 18, 2009, 06:07:12 PM »
I'm here searching for the same info. I have a 1989 3.0 5-speed truck and I found a 5-speed trans with Marlin Duals from a 1995-6 T100 3.4 for sale for a reasonable price but I need to know if it will work before I buy it. I called Marlin Crawler today to ask and the guy I talked too said I 'might' have an issue with the throwout bearing and clutch fork but he said he wasn't really sure.  :help:
And will the flywheel from that 3.4 T100 bolt onto my 3.0 so I can use a better clutch?
I hate being a newbie...
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
Re: tranny swap
« Reply #2 on: Jun 24, 2009, 05:46:43 PM »
should be possible if you can get a bell housing to match up.  read - might be easy, might require some major fabbing.
But a manual gearbox is pretty much a bunch of gears and levers, so in theory, it should work/be possible.
Last post Jan 26, 2010, 01:28:41 PM
by Grunt
Last post Jan 26, 2010, 05:44:23 AM
by ringer
Last post Aug 27, 2010, 09:02:18 PM
by 4x4yota
Last post Jul 24, 2013, 02:55:35 PM
by moutaintoys
Last post Aug 22, 2013, 04:38:29 AM
by R.DesJardin
