Author Topic: TransferCase popping out of gear???  (Read 5290 times)
sam24462
  • Male Posts: 49
  • Member since Oct '07
  • Wrecked
« on: Jun 08, 2009, 08:41:34 AM »
I need help!
Background: 1985 Toyota 4Runner.
I purchased a single 4.7 transfer case from Marlin about 2 years ago and ran that for about a year with no problems. Then I decided I wanted the second gearbox. So I bought a Marlin adapter and found a donor T-case to get the box from. I installed everything per the setup instructions and it seemed to go together fine.
Problem: Everything works good except the Front Box pops out of gear. It only happens when the rear case is in 2wd/hi and the front box is in Low. It also only happens when I am driving down hill so there is no engine load. I am on my third and hopefully final attempt at fixing this problem.  :hammerhead:
I do have the heavy duty detent ball springs in all three shift rails.
Note: I noticed that the instructions said to trim the driver side shift rail so it does not protrude out of the front of the rear case. I think that Marlin may have done this originally on the rear case because it does not protrude at all. See pics below;
Rear Case 2wd/Hi
Rear Case 4wd/Hi
Rear Case 4wd/neutral
Rear Case 4wd/Lo
I know that the shifter is not hitting on anything because I have tried driving with all covers off and it does not hit anything.
Other possible problems I have heard:
Worn gears
Worn shift fork
I included some pics of the gears, I don't see any issues with them, but maybe your eyes will notice something wrong and be able to help diagnose the problem.
I know this has been asked several times but I haven't really found the answer yet. I am at a loss on this problem :(
Wrecked
sam24462 [OP]
  • Male Posts: 49
  • Wrecked
Re: TransferCase popping out of gear???
« Reply #1 on: Jun 08, 2009, 02:48:04 PM »
:Crickets:
Wrecked
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
  • Member since May '04
  • From Reykjavik Iceland...
    • R&T
« Reply #2 on: Jun 08, 2009, 03:15:34 PM »
I dunno. I am kinda just replying to subscribe ;)
But I would try and look at how the shifter moves. how easy is it to shift and so on. I also wounder if there is any leanght difference in the shifters mabe the fork is sitting loose on the gears or something... I am just shooting in the dark tho
 2,4 dti duals 2,28 x 2,28 to 8" 5.71 with arbīs  and 39,5" trxus
sam24462 [OP]
  • Male Posts: 49
  • Wrecked
« Reply #3 on: Jun 08, 2009, 03:34:13 PM »
The shifter wouldn't matter as long as its not hitting anything such as sheet metal. The Case shifts smooth but I have the heavy detent ball springs in so I have to give it a little bump to shift.
I guess if the shift fork was worn, the clutch sleeve would have some play in it.
Can anyone get me a measurement on the shift fork.
Shift fork No. 2 from the reduction gear case. I don't have anything to compare it to.
Wrecked
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
    • R&T
« Reply #4 on: Jun 08, 2009, 04:48:45 PM »
nah... I am guessing your shifter drops out completly. if the fork would drop out from the gear you would have to disasembly the whole thing to fix... am I getting this right ???
sam24462 [OP]
  • Male Posts: 49
  • Wrecked
« Reply #5 on: Jun 08, 2009, 04:53:03 PM »
Everything works fine. It just pops out of gear and I have to stop and put it back in gear. The front case just slips out of low.
Wrecked
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
    • R&T
« Reply #6 on: Jun 08, 2009, 05:35:53 PM »
do you have a photo of the t-case shifter... installed
sam24462 [OP]
  • Male Posts: 49
  • Wrecked
« Reply #7 on: Jun 08, 2009, 06:08:18 PM »
If anything the boot is tighter in the hi gear. :sad2:
Wrecked
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
    • R&T
« Reply #8 on: Jun 09, 2009, 04:39:10 AM »
I would be looking at the boot... watch how the shifter moves when you are coasting. Also watch the other shifters they might give you a clue to what happens. = might be the problem that all the shifters move but there is a litle less free play for that one. might be resolved by some slight bending of the shifter. I had a simular problem that was resolved with bending the shifter and adjusting the shifter boot.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #9 on: Jun 09, 2009, 04:47:15 AM »
Take the boot off, and see what happens........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
sam24462 [OP]
  • Male Posts: 49
  • Wrecked
« Reply #10 on: Jun 09, 2009, 06:19:18 AM »
I am going to change the gears because I have an extra set and it is already taken apart. Then I will install it and try with no boots. I will keep this updated.
Wrecked
sam24462 [OP]
  • Male Posts: 49
  • Wrecked
« Reply #11 on: Jun 09, 2009, 09:01:01 PM »
I have a sneaking suspicion that I found the problem
I decided to change the gears that had a little wear on them and opened a can of worms. The bearing that slides over the "coupler" (not sure if that is the correct term) inside the gear is toast. I am amazed that I wasn't having more issues. The bearings were actually welding themselves to the race
The gear was wallowed out about a sixteenth of an inch. I don't think it damaged anything else so maybe I got lucky.
Wrecked
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
« Reply #12 on: Jun 09, 2009, 10:15:01 PM »
I think its awesome you have a stove in your shop, or a broken TC in your kitchen. NICE!
If you see it, its for sale.
sam24462 [OP]
  • Male Posts: 49
  • Wrecked
« Reply #13 on: Jun 10, 2009, 06:16:05 AM »
The garage used to be an apartment and I havn't finished converting yet. :)
Wrecked
Last post Jun 08, 2004, 02:49:33 PM
by dieseltoy
Last post Dec 13, 2004, 09:29:19 PM
by Marlin
Last post Dec 13, 2004, 09:38:46 PM
by Marlin
Last post Feb 22, 2005, 03:54:11 PM
by TOYJOETA
Last post Feb 26, 2010, 05:48:04 PM
by axled89
