82juguete's BUDGET trailer build
Started by 82juguete, May 13, 2009, 06:12:36 PM
82juguete
Got some small things done the last couple days...
Added triangulated corner floor bracing and undercoated entire thing...
Added some heavy plywood to floor, this not only made it stronger, but keeps the sides from being able to be pushed in... Bolted the floor down and siliconed up all the seams...
82juguete
wired up all the lights and added the side marker lights... tried to keep it clean and ran it through the frame with grommets at each hole... all exposed wire will get loomed soon...
marker lights
82juguete
And finally added the safety cables... I like these a little better than chains...
splasher
Looks like it's movin' right along!
82juguete
Yea just too bad my truck's not yet... Im waiting for the correct main bearings to come in the mail so I can finish rebuilding the motor...Not being able to drive my truck is starting to get to me!    :maddest:
crawlerdad
Well if you can't drive the truck you will have plenty of time to build the trailer. It looks like you got a lot done, and it looks good. Good idea to undercoat it. That will help to seal out the weather.
Precision guess work done here.
82juguete
Frustrating day today... Spent entire day getting what seems like NOTHING done.
Heres a preview of the lid, but it doesnt fit worth a crap!
82juguete
In theory it shouldve worked just fine... First I mounted channel on the front half of each of the sides and aluminum angle on the back half of each side, for the lid to slide into and rest on...
Heres the channel up front
Then I built 2 frames out of 3/8" square stock, and skinned them with some sheetmetal I salvaged off an old door from work.
Here you can see the 3/8" frame...
82juguete
Only problem is I mocked everything and tacked it all together in place in the channel, so I know it fit perfectly.  I had both frames, in place, fully welded and they fit perfect and the tailgate closed snugly against the lid.  Yet somehow, upon welding on the skin on the front lid, its tweaked now and is about 1" off from fitting flush on the front right corner... :dunno:  I cleaned up and called it a day before I started breaking things...
crawlerdad
Sometimes the best thing you can do is call it a day and start fresh tomorrow. When your frustrated you can miss things and take the fun out of projects. With days like this, you will appreciate the trailer more when its done. There is always ways to cover up mistakes with trim, Flashing, or paint.
crawlerdad
Well, where is this thing now? Is it registered? Is it done? Is it collecting dust like my projects?
82juguete
Collecting dust right now because:
A) i finally fired my new motor and have been focusing effort and time on that
B) i dont have the money to finish up the little stuff and/or register it right now
C) the fact that i cant even pull it till my motor has been properly broken in and has about 3000 miles on it has kinda made me figure, whats the rush?
We'll see, if my cousin wants to tow it with his runner it might get to see a few camping trips this summer...
*** YELLER ***
Dude luv the trailor i built one too but with 35's and no where as cool nice werk  :biggthumpup:
:eye: :eye: it in my Sig.
:usa: :beerwhack:
except BACON
LilGonzo86
nuce trailer ive seen it somewhere?  almost like in person
hilux-1983
Nice build. I just came into an 82 that I'm parting out and will be using the back half of the truck for making a trailer to match my rig. You've done a good thing, looks great.
Did I miss another thread of yours? You mentioned that your rebuilding your motor, what happened?
82juguete
Thanks...Old motor blew... new one's in, my build thread is in my signature.  :biggthumpup: I was going to go with a donor bed too but i like the look of a custom trailer... ill keep a eye out for your buildup.  Only thing buggin me now is i think ill only be able to tow it downhill until i do a 3rz or 3.4 swap or something...  :shudder:
hilux-1983
I remember now. I even posted some pics for you when you couldn't find what to do on the driver side of the motor (coolant plate was missing) :clap2:
82juguete
Bingo!  thats right, thanks again for that man... I've noticed you've become quite a force on this forum when it comes to helpin people out!
hilux-1983
Quote from: 82juguete on August 01, 2009, 12:42:32 AM
I like to help out when I can. Plus, it's a whole easier to explain after all of the mistakes have been made on my part. Also, If i've done it and I have pics to help I'm glad to do it. I've learned A LOT from this forum too.
Jud
"bout tree fiddy"
82juguete
Thanks... havent had time to finish this thing up and now im moving out for school so its gonna be awhile... plus ive come to the realization that i can barely make it up the 4 lane with my truck by itself, i have no clue how im going to pull this thing for camping up any type of grade.  22r just isnt up to the task, so im not sure where this project is going to head.
crawlerdad
hilux-1983
That little thing? Your worried about towing it? Kidding me right? I have a stock 22r, 529's, 35's, 5spd and I pull a 16ft utility trailer with my toys, occasionally I have to put some kinda broke down vehicle on it. It's heavy no doubt but, that Toyota pulls it and looks good doing it. You'll be ok towing that thing around anywhere. Don worry 'bout it!!!!!
GONZO97
why dont you give me the trailer ill get it registered and ill store it out here behind my garage so we can get it out of your drive way. Im sure that would make your pa happy to be able to see his driveway again. just food for thought
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
82juguete
Quote from: GONZO97 on September 02, 2009, 10:45:40 PM
uuuuuuuuuummmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
Give it to you?
No.
I will let you register it for me while im gone and have it roadworthy for me when i get back though....  :therethere:
LilGonzo86
na will just store it for you; and ill tow it and when you return ill let you use it every once and a while... HAHA
BUT FOR REALS
drdelux
Hey if you guys are really interested in a shower? You can pick up a great tankless water heater pump and battery box for about 100.00! I use an empty 30 quart cooler for the water supply, works great. Nothing like a hot shower in the woods! drdelux
82juguete
break-through.... finally got a title for it today. It probably has a lot to do with the DMV I went to, but I got no grief for having a truck axle (not to mention the fact that it sits level with my truck, and is on 33" tires that stick out enough past the trailer fenders to warrant mudflaps) I was not looking forward to the hassle, and thus been putting it off for this long, but the whole deal took about 30 minutes and I walked out with my permanent trailer liscense plate, pretty stoked.
hilux-1983
82juguete
Already getting put to use:
In the first pic you can kinda see my sweet airbag setup...not sure if I ever mentioned that in the thread. Helps the super flexy springs support loads a little better.
