Author Topic: 3 inch lift driveshaft length  (Read 2045 times)
possume22
  • Member since Apr '09
« on: Apr 22, 2009, 08:18:48 AM »
i put 3 inch spring under front of a 82 yota will i need to extend my fronf drive shaft
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: 3 inch lift driveshaft length
« Reply #1 on: Apr 22, 2009, 08:32:56 AM »
No, you will be fine with only 3 inches.
possume22 [OP]
« Reply #2 on: Apr 22, 2009, 08:56:17 AM »
ok heres why i ask i put dual casses in and used a ifs front drive shaft that was little over five inches longer the so the cases moved back six so im already one inch short dont know how much shaft travel i still need
  • Momentum Man
  • Lego Enforcement
« Reply #3 on: Apr 22, 2009, 09:07:26 AM »
Oh well that makes things a little different then, you may have issues if you've already stretched out the ds beyond the stock length. Normally I've gotten away with up to 5" of lift without issue but that's in completely stock configuration.
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
« Reply #4 on: Apr 22, 2009, 04:49:01 PM »
go flex it out on something and see if it pulls apart
possume22 [OP]
« Reply #5 on: Apr 23, 2009, 11:24:13 AM »
someone has to know how much travel i need on the drive shaft
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
« Reply #6 on: Apr 23, 2009, 12:31:09 PM »
No one is going to know how much travel you need. Too many variables come into play. As a rule of thumb you set the driveshafts up so you have 1/3 of the shaft exposed for compression and the other 2/3 for extension.
89sastoyo
  • Turtle Points: 148
  • Member since Jan '09
« Reply #7 on: Apr 23, 2009, 11:08:52 PM »
like said above to many variables. My knowledge is if your making a square tube run the big tube on the top at 12 and the bottom at fifteen works for just about any rig any lift any travel. With that said since you have duals it should be 7 inches further back then stock so make the top piece 19 and the bottom 22 and it should work but measure before cutting I wouldnt want you to cut it out and have it stuff up into your t case.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
Last post Dec 13, 2004, 08:27:04 PM
by RUGER
Last post Jan 20, 2005, 03:07:45 AM
by guywithuglyyota
Last post Mar 29, 2008, 10:21:13 AM
by 94MtnYote
Last post Jun 25, 2008, 08:38:51 AM
by MiniSimp
Last post May 30, 2010, 03:16:31 PM
by rcks4me
