Poll
What would you do after reading whats below?
1 inch body lift
2 inch shackle lift
both
niether
Author Topic: 1 inch body lift vs. 2 inch shackle lift  (Read 24844 times)
94MtnYote
  • Turtle Points: 6
  • Member since Oct '07
  • - 94 std cab-
Re: 1 inch body lift vs. 2 inch shackle lift
« Reply #90 on: Mar 28, 2008, 10:46:40 PM »
 A 1'' body lift does not lower the frame.  :psss:
   :therethere:
 Marlin 1200LB clutch
KDXSR5 [OP]
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #91 on: Mar 28, 2008, 10:54:50 PM »
   :therethere:
Yes I know. It raises the body. I am trying very hard to not get "frustrated"
Thats pretty darn nifty!
I know it will be much easier to mount sliders with a 1 inch BL, because the frame is lower down (EDIT FOR A CERTAIN SOMEONE: when compared to the body as compared to before BL) so tube can just be welded right to it easily.
Why did you make bolt on ones and not weld on ones? Ease of replacement?
Is that better?
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #92 on: Mar 29, 2008, 08:24:38 AM »
Quote
That is one of the reasons. This is the third set of sliders I have had in 12 years. The other reason is I suck at overhead and vertical welding.
94MtnYote
  • Turtle Points: 6
  • - 94 std cab-
« Reply #93 on: Mar 29, 2008, 10:21:13 AM »
Is that better?
  man I just couldn't help it
Last post Feb 08, 2006, 12:28:35 PM
by Poowoo
Last post May 14, 2006, 06:48:50 PM
by 79coyotefrg
Last post Jul 19, 2006, 02:24:24 PM
by 6.72:1
Last post Nov 15, 2007, 06:59:19 AM
by THK Matt
Last post Nov 29, 2007, 04:51:29 PM
by RN37DD
