Author Topic: TRE Taper FJ80 vs Pickup IFS  (Read 2285 times)
muddemon_06
  • Male Posts: 45
  • Member since Jul '07
« on: Apr 21, 2009, 09:45:22 PM »
Back when I did my SAS in a weekend and was trying to go cheap as possible I used my factory TRE's for the crossover steering. I used the IFS box style pitman and cut it off right at the joint and used a step drill bit as a makeshift reamer to get by for a couple trail runs. Now I'm looking for a flat pitman with the ifs style TRE taper and have had no such luck. I've got my old pitman off the taco setup for 1ton gm but it's huge compared to the TRE's I'm working with. After calling around today I heard that the taper of the fj80 rod end and the ifs rod end are close, so I figured I'd go up to the parts store and check how close they are...wrong...no one had a fj80 rod end in stock :willynilly:. And I'm not sure enough of the info I got to drop a hundred bucks on a pitman with the wrong taper. I would just buy a fj80 rod end and be done with it but that's going to cause me to totally rework the draglink. Does anyone know anything about the taper differences of these two? :dunno:
-Bo
Tow:2005 Chevy 2500HD CC Duramax LLY. Trailmaster 6" on 16x10 Moto Metal 951's wrapped in 315 Mastercraft Courser A/T's. Edge Juice w/ attitude, Kennedy boost stick, straight piped, PPE Airbox Mod, K&N. Limping the stock Ally all day long.
Play: 88 4runner SR5 SAS'd, RUF/44044 custom pack,  Highsteer, 63" rears, welded, on 315 Maxxis Buckshots for now. Waiting on a motor.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: TRE Taper FJ80 vs Pickup IFS
« Reply #1 on: Apr 21, 2009, 10:30:16 PM »
from my experiences, they are the same
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #2 on: Apr 22, 2009, 12:03:50 AM »
Great job, and right again. They are both the same.
Marlin
muddemon_06 [OP]
  • Male Posts: 45
« Reply #3 on: Apr 22, 2009, 06:45:16 AM »
Marlin
Thanks boggerunner..and you too Marlin..I tried getting through to yall on the phone there yesterday because I knew that someone there would know but I waited for someone for about 10 min and said nevermind. Anyway thanks again.
-Bo
-Bo
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • Member since Sep '06
« Reply #4 on: Apr 22, 2009, 06:54:02 AM »
Sorry I didn't answer the phone. My sleeping scedule is all messed up.
It didn't look to me like you needed the flat pitman arm. Some well placed bump stops would solve your problems, and keep your spring pack in good condition.
Call and ask if the threads are the same as what your building with. You might save some money by buying this instead of a new pitman arm.
http://www.sky-manufacturing.com/new/detaproduct.php?id=70
Toyota 23mm Pitman Arm adapter
No need to change pitman arms!
$32.00
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
muddemon_06 [OP]
  • Male Posts: 45
« Reply #5 on: Apr 22, 2009, 07:56:34 AM »
$32.00
Pretty sure those are for their crossover kits which will probably use fj80 threads.
-Bo
Last post Jun 23, 2005, 08:14:08 PM
by No Power
Last post Mar 08, 2006, 09:30:22 AM
by 4runner freak
Last post Mar 03, 2006, 10:53:55 AM
by ZukIzzy
Last post May 22, 2006, 08:48:17 PM
by yotaweelr
Last post Jun 29, 2011, 07:32:32 AM
by TacoRunner
