??? What is the taper of a fj80 tie rod end???
Started by lcruiser65, March 19, 2006, 06:28:57 PM
lcruiser65
Im wanting to redrill a scout pitman arm to fit my FJ80 tie rod ends.  Im trying to find out what the taper is?  anyone know?? I cant find it!!
im sure CruzrDave  can help you with that,  he 'll be back tomorrow
lcruiser65
 :flamer:  damn !! dose no one know the answer to my question?? :turtle:
Willy Mammoth
When I did my insert I found it to be 3*
That seems to be the best fit for me.
lcruiser65
cruzila
Willy Mammoth
I used the compound on the lathe at 3* and checked it with Prussian blue.
That was the closest I found.
lcruiser65
 :booya:  Hey thanks everyone for all the help!! im going try it this weekend gota get ready for SUMMER WHEELING!!!
Brandon
drill it out and use an insert, that's what I did anyway.
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
Willy Mammoth
Quote from: Brandon on March 24, 2006, 01:47:33 PM
Yup Drilled out to 1" and spun up an insert to weld in.
If you can find a 3* ream you may be able to do that if the hole is not too larger already.
86 4runner
where do you get an insert if you cant make one? thanks
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
Brandon
Brandon Miller
86 4runner
thanks, they're pretty pricy for something so small. its crazy.
lcruiser65
I was just planning on welding shut the exsisting hole and redrilling it with a 3* taper bit
Willy Mammoth
The weld will be kinda hard to drill unless you anneal it first. I think the insert is the best way.
yotaweelr
marlin sells the tapered adapter for about 21 bucks shipped I think it was. the taper is .75" for every 1.5'. so 1 inch tall arm would only open 1/16" from 9/16" to 5/8". I am going to be calling around looking for the tools to buy. If marlin would chime in and tell me where he got his so i can buy one....it would be awesome of him *hint*
