hope you're not asking me!
How about you share your dwg with me!Kyle@Simpson-Photography.comI'd like to see what you have done.
hope you're not asking me! MSPaint is the closest I come to CAD software. All the dimensions I have came from the azrockcrawler.com site. But if someone has dimensions for the "kingpin" at the bottom of the arms I'd like to see them (not that it should be difficult to measure). Also since we're on the topic, does this piece carry any load or can I safely assume that it's primary purpose is to locate the trunion bearings, and could it be bolted to the bottom of an arm with a 1/2" (or smaller) bolt? It seems that during hard steering the studs should carry all the shearing forces.
If someone has dimensions for the "kingpin" at the bottom of the arms I'd like to see them
thanks, seems odd that they would use 1.5" dia doesn't it?
Started by 1983HILUXSR5 Toyota Pickup/4Runner Tech 1979-95
Started by dizzydevil Parts Wanted
Started by bhigdon101 Engine
Started by muddemon_06 Toyota Pickup/4Runner Tech 1979-95
Started by fj40forlife Parts Wanted
