Author Topic: Timing issues  (Read 1168 times)
red runner
  • Member since Jan '09
Timing issues
« on: Apr 14, 2009, 07:29:31 PM »
i didnt mark my timing on my distributor whet i did a head gasket on my 20r i did the trick with the finger on the number one pistion turned it over untel it blew my finger out and then put the distributor on the number one piston but didnt work any tricks or somthing i did wrong ....could it might have been on  the exhaust stroke?? thanks guys
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Timing issues
« Reply #1 on: Apr 14, 2009, 07:34:22 PM »
exhaust stroke wouldnt push your finger off,
do it again and when you get the push of air,  look down at your crankshaft pulley and put the timing mark on 0*
you really should remove the valve cover so you can see where its going, but  using the dist cap, mark where #1 is, (should point at the vacuum advance)   then  turn it past so when it slides over the gear it comes to rest on the right spot
red runner [OP]
Re: Timing issues
« Reply #2 on: Apr 14, 2009, 07:55:41 PM »
k ill try it ..i didnt take timing chain off the crank i just put marks on the cam and the chain which i dont think its off i had the motor running but had to stop it and didnt want to start again  =s ..so when you say when i get the air look down at the pully and put it on 0 if not then put ur dist. on #1?? right??
Re: Timing issues
« Reply #3 on: Apr 18, 2009, 02:06:49 PM »
:wall:  ok  i'll say this again,  it doesnt matter about the marks on the chain forget about them
turn the motor by hand till its got the timing mark on the crank pulley lined up with the ZERO on the timing mark on the oilpump housing
then look at where the cam is at,  the timing mark on the cam should be 1/2 tooth to the passenger side of top aka 12 o clock
Re: Timing issues
« Reply #4 on: Apr 18, 2009, 02:09:03 PM »
make sure you hold the chain tight while you turn  the crank assuming its not on the cam
if it binds up at any time DONT FORCE IT :slap:
Timing
Last post Apr 19, 2004, 05:28:29 PM
by YotaYota
Last post Jul 30, 2004, 04:31:30 PM
by Skinny_Pedal
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post May 10, 2009, 01:55:46 PM
by B.P.
Last post Jul 19, 2014, 06:27:50 PM
by Chevota22
