tons 2rz three link front. Now slamming on its nuts spring under rear!newpics
Started by 89sastoyo, March 15, 2009, 11:46:16 PM
89sastoyo
Stock Birfs are amazing i dont know why they wont break?
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
toyotanner
you could of atleast took the hard line
89sastoyo
Quote from: toyotanner on July 19, 2009, 09:58:51 PM
i did there is no way i coulda went anymore up on the wall my slider was in it haha im to low and long to go up the complete face
92 2wd DD
first gen cab
89sastoyo
ya ya codys trucks like 2 feet shorter then mine lol. Are you going to bend next weekend?
92 2wd DD
first gen cab
toyotanner
no truck or trailer unless cody wants to take me :gap:
89sastoyo
i see. Well if you dont go we should go to browns cause im pretty sure he'd be more down to tow you there cause its closer lol im tryin to go there goats kinda boring
92 2wd DD
first gen cab
toyotanner
yeah i think i talked cody into taking me to browns this weekend
89sastoyo
nice :) i need to re-wire my trailer lights pretty soon think casey will tow my junk to browns if i gave him money
92 2wd DD
first gen cab
toyotanner
probably not he doesnt have those new tires on his truck yet and he doesnt wanna tow with a plugged tire but you could ask i guess.
89sastoyo
i see well i actually work now so i guess im not going. but next weekend i dont have work lets go
92 2wd DD
first gen cab
89sastoyo
Heres my buddy max's 2nd gen with a Dana 60 and 14 bolt that were building. Still needs front toy to dana 60 driveline adaptor, floor finished breaks bled seats mounted sliders shocks mounted in the front full belly pan and some other odds and ends. We rolled it outta the shop today and flexed it out in 2wd did amazing
And then i had to do it
http://i499.photobucket.com/albums/rr356/adam89sastoy/flex3.jpg
In result my axle is dumping 90wt right by my u bolts so im pretty sure my axle cracked?
92 2wd DD
first gen cab
toyotanner
maybe your spring pad is broken and it cracked the housing just weld it up its only a crack
89sastoyo
yeah i was thinking i didnt take the u bolts or plates off yet causes max's junk was in my spot in the shop haha so im probably gonna do it sometime this week
92 2wd DD
first gen cab
Halladay
did your truck pull tire flexing on the cab?
toyotanner
Halladay
yea i know mine and adams flex about the exact same so if he wasnt pulling then i dont see that being alot of flex for the 1 tons. maybe when he has tires weighting it down it will flex the 1 tons more
89sastoyo
haha yeah i was pulling my back pass rear thats 46 inches off the ground.... and max's can flex a lot more than that his wasn't even close to pulling tire and i messed with my springs since we both flexed our trucks out haha flex is over rated anyways
92 2wd DD
first gen cab
89sastoyo
haha yeah I just never pull tire wheeling unless im trying to so i don't see the point ya digg?
92 2wd DD
first gen cab
89sastoyo
so are you tryin to get your truck wheelable by friday im tryin to go mess around at goat
92 2wd DD
first gen cab
Halladay
if we can get a drivline built. but i only have that one end of the driveline cause driveline tech didnt give it back to me...... is there any other ends at the house?
toyotanner
GOD ADAM QUIT GOING TO GOAT IT IS SOOOOOOOO LAME!
89sastoyo
i know but its ten minutes from my house. Also i dont have the ford fixed yet cause i lost some bolts and need to go get new ones and haven't yet or id go to browns plus johns to much of a vagine to drive his to browns for some reason if your down on friday we should go to browns then lol have cody take you and ill see if my dads down to tow my junk
92 2wd DD
first gen cab
Halladay
why would i drive my truck to browns? thats like saying you or tanner are pus*ys for not driving your trucks there.
Halladay
plus if i break something i dont wanna get it towed. plus i wheel my truck hard. and there is hard :pokinit: there and i see myself breaking. so if you tow mine and drive yours im down! :nana:
89sastoyo
ya browns is only fifteen minutes further then goat lol. I wouldn't be driving to goat if it was't ten minutes from the crib but if you want ill drive to browns with you
92 2wd DD
first gen cab
GrenadedToy
Quote from: Halladay on August 04, 2009, 09:20:34 PM
Well maybe un-rachet strap the cage off your truck   :gap:
89sastoyo
#149
since I haven't been wheeling like i wanted to I'm gonna start tearing into my truck and re-do some things.
im going to start at the rear and work my way forwards probably do it relatively slow so if i wanna wheel i can put it together pretty quick.
Rear axle
install Diff armor
install spool
weld crack on pass perch
cut the shackle mount and spring hangers off make new hangers buy jonny joints and new shackles.
Re route exaust as high as possible take the hollowed cat off
cut crossmember off
cut floor out again
Fully flat belly it this time
Re-do floor a better way.
full belly pan
maybe 4.7s and 23spline if i can afford it
install new sliders
front axle
install 30 splines
weld shock mounts and ball gussets on the new front axle
put axle together and throw it under
tub the fire wall so I dont rub at all
Motor
All fluids figure out why im throwin check engline lights
cap rotor plugs wires
header
make and intake for it
mount msd better
built a cage got a hydrolic bender not sure if im going interior or exo yyet so thats hte last on the list:)
92 2wd DD
first gen cab
