Toyota 2L (2.4 liter) diesel
Started by LWB_Samurai_Joe, June 05, 2002, 01:10:42 AM
LWB_Samurai_Joe
Anyone else using Toyotas 2L 2.4 liter diesel?  I love it.  With 5.29's my rigs running 42x15's and I get 34 MPG.  Makes those long 4x trips a breeze.  This motor is RARE in the U.S., only imported '84-85.  Thought I'd look here and try and find others who might have experience with it.
Tom Bentzen
1988 long wheelbase Samurai
1984 toyota 2.4 liter 2L diesel motor
1984 toyota G52 5 speed tranny
1984 toyota front axle, 5.29 gears, ARB locker and high pinion 3rd member
1984 toyota rear axle, 5.29 gears, ARB locker and V6 3rd member
Marlin 4.70
RogueDogg
#1
Nice ride that is by far the best looking Sami I've ever seen. I've been contemplating on building a Sami and now with your post it renews my faith that I can too build a monster out of a mouse. Nice job and look forward to maybe seeing some wheeling pics and other info on it. Hey just wondering but how come you don't have the R151F turbo tranny behind that turbo diesel? I know they're really hard to find and expensive, I just put one in my 85 Toy p/u 4x4 *(took out the A340H auto)* Loving every min of the swap so far.
Brian "ROGUEDOGG" Ford
LWB_Samurai_Joe
#2
R.D., thanks.  I plan on installing one of Marlins 5.15 first geared trannys!  Just one of the many inprovements I'm making.  I'm also going to get one of his Toy60's.  The rig came out of B.C. canada. She is a sweet ride.  That Front range full floater is very cool too.
I'll get some wheeling pics soon.
My other sami!
Marlin 4.70
#3
Oh my gosh!  :o That's way wicked man!
What state are you in ?
#4
The bigger the tire, the smaller the obsticle!
 :greengrin: ;D
LWB_Samurai_Joe
#5
Hey Mike, I live in the Seattle area.  Thanks.  Wheel a bunch up here too.  Pretty much every weekend.  What do you think of that rear steering Idea?
TB
Marlin 4.70
90TOYPU
#6
WOW that engine sounds nice I would love to get that kind of mileage.
HELLO
rEdnECkwHeE1eR
#7
my friend is getting an 84 or 85 x cab with a non running turbo diesel in it how could we find out whats wrong with it :help:it would be cool to run that moter
Liquor up front
Poker in the rear
LWB_Samurai_Joe
#8
Good luck.  NOBODY knows anything about those engines!!!  Your best bet is to get ahold of someone in Canada.  Call this guy:
http://www.kodiakcustomvehicles.com.futuresite.register.com/
Cody is his name.  He can help you as much as anyone.  Your gonna have to find a very good Toyota dealership that can get you parts.  Not all of them can.
Good luck
Tom B
Marlin 4.70
supra
#9
That will be a 2L-T
Check the timing belt and tensioner they can fail if not replaced regularly.
If the motor cranks over OK crack one of the injector nuts and see if you get fuel.
If it runs like a dog you could have dead glow plugs or cracked head which is also common.
Mike
PS we have heaps of 2L-T's over here in New Zealand ( most comon engine here )
rEdnECkwHeE1eR
#10
yup 2L-T I dont Know if well ever find parts for atleast not with out many $$$
No bodey knows any thing about these engines were geting from a Toyota Mechnic  :ugh:
Do these engines have the same bell hosing patern as the 20-22r/res(will it bolt to a comon 5 spd?)
Also do they have reliabity problems like the gas Turbos?
many ???s but I need  :help:
Many Thanks
Liquor up front
Poker in the rear
supra
#11
The 2L and 2L-T have a factory bellhousing comon only to the diesel motors which will bolt upto the G52 and W56 gearbox.
There are 2 versions of the 2L-T, one has an aluminum tappet cover the other is steel. The aluminum covered version uses a rocker shaft to operate the valves the steel one has the cam run directly onto the valve gear.
The main issue here is the heat from the turbo causing the heads to crack. The best solution is to use a big exhaust (2.5 inch) to get rid of the heat.
heaps of parts here for them but I would expect the shipping costs to be high, although $US1 buys over $NZ2
Mike :)
rEdnECkwHeE1eR
#12
Is there any way to use the 2wd tranny its hooked to in a 4wd :confused: :confused: :confused:
Liquor up front
Poker in the rear
wheeloverhondas
#13
im redneckwheelers freind with the truck its mine not his
87 xj, dana44/60, welded front and rear,hysteer being made,38s,and lots more
rEdnECkwHeE1eR
#14
Quoteim redneckwheelers freind with the truck its mine not his
The doors are mine :moon:
Liquor up front
Poker in the rear
Native Warrior
I have a 1984 2.4 liter Diesel here in Oregon and I'm having trouble finding a head gasket and water pump for my truck. I'm trying to find Toyota part #'s for the water pump and head gasket so I can buy them to get my diesel back on the road any help please is appreciated.
Please call if you have any info or sources for parts.
Johnny
Native Warrior
Well I finally found a 2 L diesel head for my truck and I might be parting ways with my diesel Toyota after all. Not sure what the going price is for one of these truck s though?
helipilot77
Sorry I didn't see your post earlier I could have helped you out. Dave Stedman at Japan4x4.com  [email protected] can get you just about any part that is still available. Gaskets and a water pump would have been easy for him. Find your part numbers on Toyodiy.com. If you create an account it will show you the diagrams as well. He takes PayPal. Shipping is surprisingly reasonable and quick. He has been a huge help while I rebuilt my 1KZ-t.
Native Warrior
Anybody have a to 2L head for a diesel toyota non turbo for sale?
helipilot77
Native Warrior
I e mailed him in Japan and he has no sources for a 2 L non turbo cylinder head at all anybody have any sources for a head? Johnny
OVRAROK
Quote from: Native Warrior on April 17, 2020, 11:04:48 AM
https://www.ebay.com/itm/192940683840
Native Warrior
Hello everyone, can anybody help me with the valve adjustment specs after I installed the new head I need to adjust the valves. Can you guys help with this? Also I'm going to put a bigger either 2" or 2.5" exhaust on the 2L engine. This truck is all factory no mods to the engine. Stock exhaust is still on the truck. I'm trying to get more horsepower for going uphill on highway speed is all. Maybe a engine swap? Any recommendations for a swap?
