Author Topic: 4 & 5 Point Seat Belt / Harness Mounting... How did you do your's?  (Read 9668 times)
Redbeard1
  • Turtle Points: 54
  • Male Posts: 414
  • Member since Mar '07
    • Project Pete
 :help:   Looking for ideas on how to mount my 5 point harnesses in the cab of my truck.  Do not have or want "full" interier cage (planing exo) but I am considering building a frame behind the seat from the floor to just below sholder level for this purpose. I do want the interier frame tied to the frame for strength and i plan to solid mount the cab as well. Post up some pics of how you have attached and mounted yours.
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
 __________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
smokeater87
  • Turtle Points: 11
  • Male Posts: 128
  • Member since Oct '08
Not sure if i did it right and its not done yet but i bolted the lap belt portion where the existing seat belts were on the floor.I just unscrewed them and bolted it in.Ill try and get some pics of it for ya.
Putting the wet stuff on the red stuff!!!!
joey0712
  • Male Posts: 1,459
  • Member since Apr '08
Its kinda hard without having tube ran inside the cab. What kinda chairs do u have?
91 Toyota High pinions f&r.
4RunnerChevy
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Redbeard1 [OP]
  • Turtle Points: 54
  • Male Posts: 414
    • Project Pete
Thanks guys, I have some Scat Sport Seats. I am gonna run some tube inside but just enough for the harness mounts.
« Last Edit: Mar 08, 2009, 11:21:45 PM by redpim1 »
RIP Bobby Long
joey0712
  • Male Posts: 1,459
Sounds like a plan if your gonna run SOME tube.... Might as well just build yourself a full on cage ???
Redbeard1 [OP]
  • Turtle Points: 54
  • Male Posts: 414
    • Project Pete
If you have somthing simular to what I am talking about post up.  :biggthumpup:
« Last Edit: Mar 08, 2009, 11:38:45 PM by redpim1 »
RIP Bobby Long
joey0712
  • Male Posts: 1,459
This is kinda all i could come up with. Its gonna be hard making it strong enough with out going crazy.
Redbeard1 [OP]
  • Turtle Points: 54
  • Male Posts: 414
    • Project Pete
that is what I was looking for. :thumbs:
Are you using bolt in belts or wrap around belts in your truck?
Im planning to use bolt ins and use full circle tabs for the ancors.
How are your sholder belts actualy attached to the cage?
RIP Bobby Long
joey0712
  • Male Posts: 1,459
The sholders and just tied off to the tube. The lap belts and bolted to a tab bolted with a grade 8 bolt.. I still might throw the nut straps in also
Redbeard1 [OP]
  • Turtle Points: 54
  • Male Posts: 414
    • Project Pete
Thanks Joey...
RIP Bobby Long
Redbeard3261
  • Male Posts: 133
  • Member since Feb '07
  • <center>
Here is how I did mine, but I went with full inside cage
joey0712
  • Male Posts: 1,459
i like the seat mounts...
Redbeard3261
  • Male Posts: 133
  • <center>
Yea me and my son built those so they go through the floor and tie in directly to the frame same with cage
joey0712
  • Male Posts: 1,459
Mnmstoy
  • Turtle Points: 50
  • Male Posts: 230
  • Mike's 80Toy
here is how I mounted my shoulder harness.
lap belts are under the rear seat bolts. I did plate the bottom rear so the bolts don't pull through.
Mike
sorry for the cell phone pics. At the time I could not find my camera.
DieselD
  • Male Posts: 409
cut most of my cab off and tie everything together
Last post Jun 02, 2004, 10:45:33 AM
by Brandon
Last post Dec 06, 2004, 11:10:00 PM
by Luys4Runnen
Last post Mar 14, 2007, 08:31:26 PM
by skyscraper
Last post Sep 05, 2007, 07:12:20 PM
by gupster
Last post Jan 30, 2009, 06:31:43 AM
by MiniSimp
