4 & 5 Point Seat Belt / Harness Mounting... How did you do your's?
Started by Redbeard1, March 06, 2009, 05:18:56 AM
Redbeard1
 :help:   Looking for ideas on how to mount my 5 point harnesses in the cab of my truck.  Do not have or want "full" interier cage (planing exo) but I am considering building a frame behind the seat from the floor to just below sholder level for this purpose. I do want the interier frame tied to the frame for strength and i plan to solid mount the cab as well. Post up some pics of how you have attached and mounted yours.
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
smokeater87
Not sure if i did it right and its not done yet but i bolted the lap belt portion where the existing seat belts were on the floor.I just unscrewed them and bolted it in.Ill try and get some pics of it for ya.
Putting the wet stuff on the red stuff!!!!
joey0712
Its kinda hard without having tube ran inside the cab. What kinda chairs do u have?
91 Toyota High pinions f&r.
Redbeard1
Thanks guys, I have some Scat Sport Seats. I am gonna run some tube inside but just enough for the harness mounts.
RIP Bobby Long
joey0712
Sounds like a plan if your gonna run SOME tube.... Might as well just build yourself a full on cage ???
Redbeard1
Quote from: redpim1 on March 06, 2009, 05:18:56 AM
If you have somthing simular to what I am talking about post up.  :biggthumpup:
RIP Bobby Long
joey0712
This is kinda all i could come up with. Its gonna be hard making it strong enough with out going crazy.
Redbeard1
that is what I was looking for. :thumbs:
Are you using bolt in belts or wrap around belts in your truck?
Im planning to use bolt ins and use full circle tabs for the ancors.
How are your sholder belts actualy attached to the cage?
Quote from: joey0712 on March 10, 2009, 08:36:08 AM
RIP Bobby Long
joey0712
The sholders and just tied off to the tube. The lap belts and bolted to a tab bolted with a grade 8 bolt.. I still might throw the nut straps in also
Redbeard1
RIP Bobby Long
Redbeard3261
joey0712
Redbeard3261
Quote from: joey0712 on May 10, 2009, 10:29:43 AM
i like the seat mounts...
Yea me and my son built those so they go through the floor and tie in directly to the frame same with cage
joey0712
Mnmstoy
here is how I mounted my shoulder harness.
lap belts are under the rear seat bolts. I did plate the bottom rear so the bolts don't pull through.
Mike
sorry for the cell phone pics. At the time I could not find my camera.
DieselD
