hopefully its just the new surfaces and needs to be ran for a little bit?
Pedal pressure is okay. Its better than when i had the 22rte in. But i would like a firmer pedal. I have bled the think like 3 separate times. I cracked the bleeder and gravity bled the slave cylinder, then i did the usual pump the clutch hold it to the floor and crack the bleeder, then i let it sit for a day and did the same again. Still leaves a little to be desired. Slave cylinder is New factory Toyota. Clutch master cylinder is from Marlin.
Thanks I will look into that because i wood like a firmer pedal.
What is URD? I tried the dealer for them in AZ and they don't stock them, I will have to order it. Thanks
Started by derek Engine
Started by wrenchtech Engine
Started by BigMike New Announcements and Info
Started by SqWADoosh « 1 2 » Transmission/Clutch
Started by GreenYoterKrawler Toyota Pickup/4Runner Tech 1979-95
