1984 Clutch Upgrade to Turbo & Late 22RE Clutch
Started by wrenchtech, March 17, 2005, 07:57:17 AM
wrenchtech
Call me Stymie! Cause I'm stymied :confused:  I got a 1987 R151 "turbo" tranny and t-case for my '84 Xtra Cab :thumbs: Now I just need to know which clutch parts to run with it. I want to go with the larger diameter clutch of the turbo motors and the  '93 - '95 22RE.  A local wrecking yard has a large diameter flywheel off of a '95 22RE I can get cheap and I was thinking of using a clutch kit for 93- '95 trucks that has a throwout bearing, pilot bearing, clutch disk and pressure plate included. Now I'm just trying to figure out which throwout bearing hub I need to run with the late style clutch parts and will the R151 clutch fork that came with the tranny work with that. -- Matt
1999 4runner SR5, 3.4, auto, Horizon Blue
wrenchtech
The top image (below) is the throwout bearing for the early R151F clutch, and which seems to be the same one indicated for most  early 22R - RE trucks through 7/88.
The image on the bottom is the throwout bearing indicated for the 22RTE with the R151F after mid 1987; and for the regular 22RE with manual transmissions after 7/88.
Question: Does the later bearing act as a hub and bearing all in one? Or does it also ride on a hub. And woud it require a different fork than the earlier bearing?
the top image is just the bearing the sleeve is pressed into it
wrenchtech
Isn't there a little more to it than that? The lower picture shows a late model t/o bearing that has an integral hub as part of the unit and integral retaining clips. -- Matt
the one on top when pressed onto the sleeve is much beefier looking than the bottom one,   but you gotta put the clips on yourself
wrenchtech
Quote from: 79Coyotefrg on March 18, 2005, 08:10:50 AM
So it sounds like I could go either way using the same fork.  My clutch kit is coming with the later style bearing, but I have an early style hub, so I'll check to see if they both work.  Thanks
yes i think they are all the same inside diam.
