Thanks!So I use a 14mm socket to loosen the plug or a 17mm?
the drain is on the drivers side of the block about half way of the block height but is closer to the rear of the block, it SHOULD have a 14mm plug inside 17mm outer drain thingy
Started by lowgeared Engine
Started by dothemonkey Toyota Pickup/4Runner Tech 1979-95
Started by agrout Toyota Pickup/4Runner Tech 1979-95
Started by KauriJ Newbie Questions
Started by slowpos New Member Check-In!
