Author Topic: Antifreeze engine block drain plug?  (Read 9323 times)
dothemonkey
  • Turtle Points: -71
  • Male Posts: 31
  • Member since Sep '05
  • Work in Progress
« on: Oct 27, 2007, 08:06:14 PM »
I was driving on the freeway today and when i pulled off, steam/smoke was pouring out of my engine.  Never a good sign and the second time in a month now.  When i popped the hood i could see the liquid was coming out of the rear of the engine, a 22re, and it seemed like it was about where the head attached to the block or maybe a bit lower than that.  Somewhat fortunately i was right by a Jiffy Lube so i was able to roll my truck in there.  The guy that took a look at it said that i was leaking coolant.  i still have the same amount of oil so it seems as though the head is fine.  One of the guys at Jiffy Lube mentioned a antifreeze plug and that it may have fallen off.  I personally have never heard of one and could not find any info while hunting around the net.  if anyone could confirm that this is a possible problem or offer any other suggestions i would appreciate it.
fordh8r
  • Turtle Points: 850
  • Male Posts: 2,588
  • Member since Jan '07
  • when my toyota grows up it'll be just like my chevy!
Re: Antifreeze engine block drain plug?
« Reply #1 on: Oct 27, 2007, 08:29:51 PM »
Freeze plugs have been known to fall out but not as commonly as them rusting out and leaking  :yesnod:.  They aren't expensive at all, merely pennies  :twocents:.
But replacing them can be a chore depending on it's location in the engine block.  I would recommend replacing as many as practical, since if one failed others may be soon to follow. Good luck with replacing those.  :crossed:
ROKNROLLR
  • Turtle Points: -17
  • Member since Apr '06
« Reply #2 on: Oct 27, 2007, 08:59:28 PM »
On the 22re  the coolant drain plug for the block is located (driver side of engine block-top right). It's a little difficult to see but it's there.
Prismo
  • Turtle Points: 8403
  • Member since Oct '03
  • Living in the green house
« Reply #3 on: Oct 27, 2007, 09:26:03 PM »
Drain plug is below the exhaust toward the back of the block. There is also a plate on the back of the head that can leak. Hard to see, almost need a mirror to see it back there. Water bypass pipe also runs below the exhaust. Another possible source.
SolidAxle
  • Turtle Points: 6
  • Male Posts: 365
  • Member since Oct '05
  • My truck is 5 years older than me
« Reply #4 on: Oct 28, 2007, 09:18:51 AM »
JUST FOR YOU...
be Careful there is also a frost plug on the back of the block :ack:
The plate on the back of the head is actually an egr port. FSM calls it an egr cooler. The pipes i defiantly agree with one of the pipes going through the firewall split on my truck. It was certainly alot of fun to replace. :shake:
dothemonkey [OP]
  • Male Posts: 31
  • Work in Progress
« Reply #5 on: Oct 28, 2007, 10:51:37 AM »
Thanks a bunch, those pictures are exactly what i needed.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
« Reply #6 on: Oct 28, 2007, 10:54:13 PM »
JUST FOR YOU...
that's because there is coolant behind that plate, which cools the EGR gas flowing through the plate.
SolidAxle
  • Turtle Points: 6
  • Male Posts: 365
« Reply #7 on: Oct 29, 2007, 02:11:16 PM »
you may be right, but the passage way(the squggily ridge in the plate) has exaust gases flowing through it. i figured it was a cooler because it was out in the open on the back of the head, and thats what made it cool down.
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #8 on: Oct 29, 2007, 02:17:04 PM »
i would think the rear coolent tube would take a poo befor the plug came out/rusty
also on the rear of the head theres a cap with gasket.
dothemonkey [OP]
  • Male Posts: 31
  • Work in Progress
« Reply #9 on: Oct 29, 2007, 05:36:01 PM »
Well i got a chance to actually look at it in the daylight and i was happy to find one of my heater hoses had a huge split in it.   :hammerhead:  The one from the metal pipe that goes behind the block.  When i did look at where the freeze plug was on the back of my block i was really happy it did not happen there.  Thanks for the help to those who posted, it was good to know even if that isn't what happened.
ROKNROLLR
« Reply #10 on: Oct 30, 2007, 03:19:35 AM »
I would highly suggest you pressure test your coolant system, since one hose fail you might as well check everything and see what leaks, split/cracked/worn hoses. Change at least all the hard to get to ones..bypass,heater,metal lines...etc, when you are done use good coolant like Toyota/DexCool. Make sure all your grounds are cleaned and connected so you won't get any electrolosis-very common on Toyotas
dothemonkey [OP]
  • Male Posts: 31
  • Work in Progress
« Reply #11 on: Oct 30, 2007, 10:22:16 AM »
I replaced most of my hoses when i put in a new head.  I just never got around to replacing that one and i knew it needed to be.
Last post Jul 06, 2004, 02:23:29 PM
by superstarai
Last post Feb 04, 2009, 11:45:35 AM
by JD
Last post Jul 30, 2010, 10:54:33 PM
by Cheesemaker
Last post Aug 08, 2020, 02:00:46 AM
by Gnarly4X
Last post Jun 10, 2022, 11:14:56 AM
by slowpos
