Author Topic: Will marlins output combine with trail gears 4.7 gears  (Read 3693 times)
Stew Padidiot
  • Turtle Points: -2
  • Member since Nov '07
« on: Jan 28, 2009, 09:22:29 PM »
i have an 88 toy with tripple t-cases with 1 ton axles i didnt gear the axle and i broke a turbo 23 spline output and then i threw a trail gear 4.7 kit and broke that 23 spline shaft will marlins output work with trail gears,gears
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
Sounds like you need to spend some  :twocents: on some gears for the axles.
And most of us don't buy TG parts, for a simple reason.  They are cheaper for a reason!
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
your rear output on the turbo t-case is still 21 spline  only the input is 23 spline.
so yes marlins and bobby longs output shafts will work
:nonono:   NO
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
You will continue breaking input gears due to lack of total spline and other very important factors. There are major reasons why cheaper parts are cheap.
My H/D output shaft will work with all transfer case gears and as a result of the significant upgrades, is the strongest and best designed output available.
Cheesemaker
  • Male Posts: 4,525
The KING  :king: has spoken!
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Annihilation Fabrication
:nonono:   NO
dont tell people misinformation just because you dont like the company....
Do you need a Hammer?
Stew Padidiot [OP]
  • Turtle Points: -2
well i did trail gears 4.7 gears cause they were a good deal at the time and tg wants to hassle me on replacing it i broke the input faster than you can blink so then i had a stock turbo t-case and threw it in and that held up allot better and longer put then eventually i broke it so i no i got to do gears in the axles but i want to no if i can use trail gears 4.7 gears but use marlins 4.7 input to save a few bucks..any and all info. is good so thanks  :help:
Last post Nov 22, 2004, 01:23:14 PM
by Drachota
Last post Dec 28, 2006, 08:59:01 AM
by iNfErNaL
Last post Aug 14, 2007, 05:01:22 PM
by snowshoebrue
Last post Apr 26, 2008, 07:40:59 PM
by bonebuilt
Last post May 08, 2011, 08:18:17 PM
by Tofudude
