Author Topic: dual case problems..  (Read 3203 times)
89sastoyo
  • Turtle Points: 148
  • Member since Jan '09
« on: Jan 22, 2009, 08:17:08 PM »
So I just put my dual t cases in my truck and it was making a wining noise, from there i talked ot my friends filled it up from the shifter now  so i did this and it seemed to fix it then a couple miles later it started doign it again. Does any one know what the problem could be or has had it? The bad part is my rear case is unknown because i had to use my old case for the reduction box because its a forward shift tranny.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
Re: dual case problems..
« Reply #1 on: Jan 22, 2009, 08:23:06 PM »
did you put a quart in the crawl box as well as filling the rear case? also could the noise be coming from your transmission?
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
89sastoyo [OP]
« Reply #2 on: Jan 22, 2009, 08:24:24 PM »
i dont know how much i put it ill drain it and measure a quart then fill the other one up from the fill hole? and im pretty sure its not the tranny it never made noises before and is full of fluid
92 2wd DD
first gen cab
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
« Reply #3 on: Jan 22, 2009, 08:29:34 PM »
I run 1 quart in my crawl box (filled through the shifter) then I fill the rear case through the fill hole till it comes out the hole.... use 80W-90 gear oil also
www.choptechfab.com
CHECK THE BUILD
89sastoyo [OP]
« Reply #4 on: Jan 22, 2009, 08:47:27 PM »
ok ill do that and i have shittyy oil think that could be a factor? its 85 140 thats all that knechts had i just wanted it to be driveable till i can get everything dialed in and i can get it changed for free at oil can henrys thats what my plan was i just didnt think that the oil being thinner would make that much of a difference considering its still gear oil
92 2wd DD
first gen cab
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
« Reply #5 on: Jan 22, 2009, 08:48:43 PM »
where you located?
www.choptechfab.com
CHECK THE BUILD
89sastoyo [OP]
« Reply #6 on: Jan 22, 2009, 09:04:20 PM »
im near portland oregon you?
92 2wd DD
first gen cab
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
« Reply #7 on: Jan 22, 2009, 09:17:26 PM »
im down the freeway in albany
www.choptechfab.com
CHECK THE BUILD
89sastoyo [OP]
« Reply #8 on: Jan 22, 2009, 09:40:15 PM »
where do you wheel? browns?
92 2wd DD
first gen cab
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
« Reply #9 on: Jan 22, 2009, 09:47:50 PM »
ya pretty much there are a few places down here but its all weak as hell
www.choptechfab.com
CHECK THE BUILD
89sastoyo [OP]
« Reply #10 on: Jan 22, 2009, 09:56:14 PM »
yeah for sure we have goat mtn up here its like twenty minutes closer then browns but its like mess around have fun but it gets old for sure im trying to get my truck done and make a big trip to browns but everyone i wheel with has there trucks apart right now so im waiting for them and wheeling with some not as built trucks
92 2wd DD
first gen cab
toyman80
  • Member since Aug '08
« Reply #11 on: Jan 29, 2009, 11:13:52 AM »
let me know how this works out for you.  im about to do duals on my rig also so i wan to make sure i cover all my bases.
as for browns camp a bunch of us vancouver guys are trying to have a run around the end of april. itll be a bunch of cherokees and a few yota and samis if your interested.
CrankyCrawler
  • Turtle Points: -1
  • Male Posts: 30
  • Member since Dec '08
« Reply #12 on: Jan 29, 2009, 01:01:25 PM »
I am definitely not an expert on it, but the duel cases make quite a bit of noise when driving down the road even if they are filled to the proper level. My cases were installed by ORS with the MCR10 adapter. The shop owner took me for a ride before I picked the truck up to let me hear how much louder it would be than when I had a single t-case. Also, I have a FROR x-member so that is probably contributing to the noise/vibration.
1984 Toyota Pickup: Dual Ultimate with 4.7's in rear, R10 FROR Crossmember, FROR Twin Stick, Aussie Front with 4.88's and 30 Spline Longfield's, Rear Detroit with 4.88's, Custom ORS front and rear bumpers, ORS sliders and shock towers, Alcan 4" springs, 35" Cooper Discoverer MT's, Bed bobbed 12", and Soft Top.
http://www.offroadsolutions.com/customerprojects.html - Robert's 1984 Pickup
http://www.offroadsolutions.com/orsbbq08.html
germ
  • Turtle Points: 349
  • Male Posts: 733
  • Member since Dec '04
  • Work sucks, I'm goin' wheelin
« Reply #13 on: Jan 29, 2009, 10:27:51 PM »
I don't recall my dual cases making any more noise then before they were installed. Hmmmm Sounds a bit funny to me. I'd make sure that the cases have the right amount of a good quality gear oil. Could also put in some Lucas Oil treatment or some other stabilizer (royal purple?). I've also heard that there can be some whining for a while while the bearings seat, but don't have first hand experience with this.
erik
80_yota_pickup
  • Male Posts: 86
« Reply #14 on: Jan 29, 2009, 11:12:50 PM »
do you know what year you cases are? cause the early t-cases are known for having a wining noise especially when put in to duals. does it make the noise all the time or just in certain gears?
SAY i WON't... AND i WILL
80 pickup SB with 87 4runner SR5 interior,22re swap, welded F&R, 5" allpro springs, ultimate duals, 36" iroks, DIY beadlocks,SB bobbed 16",
coming next: full cage, longfields, and 5.29's
toyman80
« Reply #15 on: Jan 30, 2009, 12:06:07 PM »
i know my 84 yota with single forward shift tcase makes a bit of whining noise in 4lo.......
Last post Mar 02, 2006, 11:08:54 PM
by toysfreak
Last post Jan 23, 2007, 01:25:14 PM
by Boheefus
Last post Nov 28, 2007, 10:59:58 AM
by dirtchicken
Last post Oct 23, 2007, 01:17:01 PM
by mmessier2
Last post Aug 13, 2008, 08:55:24 PM
by focushere
