Project BoostedRunner, SOLD
Started by pumkin toy, January 12, 2009, 09:37:34 PM
Uncle Ben
I'm on it man!  You have any bargaining hardware?  Keeping it on this forum might shake on out too I'm figuring! ;)
Kevin Ehrlick
"I pledge allegiance to Marlin...." :)
'64 FJ-40 crawler (Wild Rice)
'97 FZJ-80 mall rated (Rice Cake)
"Chrome wont getcha home!"
pumkin toy
Quote from: Uncle Ben on January 29, 2012, 09:12:32 PM
i dont really have anything to bargain with unfortunately.  Thanks for helping out though!
97 4runner Limited
NITE KRAWLERS
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
Uncle Ben
Hows it going sir?  Get the 40 cage done so you can dazzle us with more WOW?
Kevin Ehrlick
pumkin toy
Quote from: Uncle Ben on March 10, 2012, 09:27:21 AM
the 40 cage was done a few months ago.  working on skidplates now.  i did get the rear swing out tire carrier done too,  i will post some pics of that
97 4runner Limited
Uncle Ben
Quote from: pumkin toy on March 12, 2012, 03:07:41 AM
:thumbs: :thumbs: :smokin:
Kevin Ehrlick
pumkin toy
sorry guys, didnt have time to get pics of the tire carrier and hydro assist steering today.... hopefully tomorrow!
97 4runner Limited
Jud
"bout tree fiddy"
Uncle Ben
Kevin Ehrlick
pumkin toy
97 4runner Limited
toyotanner
assuming hes talking about the  4.7 gears ???
or probably the fj build
pumkin toy
Quote from: toyotanner on April 15, 2012, 10:23:12 AM
im thinking the 4.7 gears i guess.   i just got that FJ40 out of my garage friday.  been working on it for about 6 months and im glad to finally have my own rig back in my garage!
97 4runner Limited
Uncle Ben
3 pages back was how far this thread was buried.  Just missing my SD friend fix.....  :beerchug:
Kevin Ehrlick
pumkin toy
Quote from: Uncle Ben on April 15, 2012, 11:48:52 AM
oh  haha  yeah i havnt even had my own rig in my garage for 6 months so there hasnt been any updates!  i plan on doing some more work on the cage here soon so i will keep everyone updated
97 4runner Limited
TRACKER
this build is bad a$$  :respect:
I'm planning doing 3 link with fj80 hp axle and really like the way you have the steering set up .
can you please get a close up pictures of the steering arms  ,it look like you did double shear
Pride - is what drive a man to do his very best even when no one is looking ..
pumkin toy
Quote from: TRACKER on April 16, 2012, 10:27:23 PM
thanks dude, i appreciate the comments!  if you go to page 70 of my build and scroll down about halfway there are some good pics of the steering arm setup.   What i did was take the driver side arm and cut the front facing half of the arm off right at the knuckle bolts, then spun it around 180 degrees to see how it would fit.  The arm was rubbing on my tire when it was bolted on so i cut it off and welded it back together at an angle that would not rub on anything.  i made a gusset for it and warmed the whole thing up with a torch and welded the gusset in.  The cast steel actually welded really nice.  then the passenger side arm i left mounted the regular way, just cut off the rear half where the original tie rod connects.   Then i took both arms to work and put them in the mill to have the tapered tie rod hole drilled out to a 3/4" hole so a bolt would fit through for a heim joint.  then i fabbed my own upper arms out of 1/4" plate and installed a 3rd stud in each knuckle where the abs sensor was.  Its hard to explain step by step, if you look back before page 70 i think there are pics of when i welded the arms together and everything.  Hopefully this info helps!  So far things have been holding up just fine with no breakage and the price was right too! Basically free....  alot cheaper than the high steer knuckle setup from the company that offers it.  although it does look like they make a nice product
97 4runner Limited
TRACKER
 i fast read thru the build .. i have your photobucket album saved  as my favorite .. i saw how you did the lower arms but i could not make out what you did to the upper arms . now i fully understand it with the 3rd bolt . my next question was  how are they holding up , look like they re holding up fine from the pictures of the trail you re riding ..  i wanted the hi steer kit but not right now . thanks for clearing it up  :beer:
pumkin toy
Quote from: TRACKER on April 17, 2012, 07:21:07 PM
They have been holding up great so far.  the only issue is the knuckle studs came loose once, but i did not have lock tite on them so thats probly why.  so far no breakage though
97 4runner Limited
pumkin toy
So now that i have my 4runner back in the garage i'm stoked to work on it again.  i worked on the cvage this weekend.  i replaced the vertical sections of the main hoop because i didnt like how big the gap was between the body and cage.  then i added on some more pieces to cage in the back seat area.  i put a couple verticals through the floor to the frame on each side to give it some more support and im also going to mount a cross tube right behind the seats to connect 4 point seatbelts to.  Ive decided that a hardtop of some kind will not ever be going back on. the plan right now is to just get a bikini top that will snap onto the cage and cover the rear seat section.   sorry for the crappy cell pics, i need a new camera Really Bad!
97 4runner Limited
I'm totally envious of your setup bro, do you think 80's series axles would be doable with leafs?
pumkin toy
Quote from: THK Matt on April 22, 2012, 08:19:03 PM
yeah im pretty sure you could run leaves with them.  i think the guy that manufactures the high steer knuckles for the 80 series axles runs leaves on a first gen pickup with 80 seres front axle.   i dont see why the rear axle wouldnt work too
97 4runner Limited
John Doe
I am running Leafs with an fj80 front end currently. The only to run leafs with the rear axle is to use a fuel cell or a tacoma since there would be alot of interference between the gas tank and the drive shaft.
pumkin toy
im really disappointed at how crappy those pictures look!  haha  i will try to get my camera to work this evening and get some better ones
97 4runner Limited
Thanks guys, and John Doe, I forgot you switched to an FJ80 front. and who makes the knuckles?
EDIT: found 'em.
John Doe
I see that you found it, but for anyone in the future that is curious.
http://hellfirefabworks.com/fj80hsu/
Uncle Ben
Bump up!   You got that machine ready to rock yet?
Kevin Ehrlick
Jaysen
He got some gears and locker coming and soon he should be up and running!!
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
Gixxer Jon
Hillcrest Crawlers
_________________________________
||_________||_________||__TOYOTA_||
||_________||_________||__________||
http://board.marlincrawler.com/index.php?topic=67011.0
pumkin toy
Quote from: Uncle Ben on May 22, 2012, 07:55:22 PM
hopefully i can go wheel the crap out of it here within a month.  diff gears and a front locker are on the way.  I have the next 4 days off so i plan on tearing down both axles and getting them ready for the gear install.  I also still havnt even painted my front axle with thoughts in mind that i would be tearing it down for gears eventually. so i am going to clean it up and paint it this weekend too.
97 4runner Limited
