Author Topic: 2RZ 3RZ TRD SUPERCHARGER KIT + EXTRAS [SOLD!]  (Read 20963 times)
  • Trade Count: (+1)
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« on: Jan 10, 2009, 06:29:07 PM »
I am selling my Alpine TRD Supercharger Kit for any 1995-2004 2.4 liter 2RZ-FE or 2.7 liter 3RZ-FE found in Tacoma's, 4Runner's, and T100's (1995-97).
PRICE: $1,900
I sold it on eBay back in October for $2,000 to a guy near Oakhurst, CA, but it turned out he had a T100, and after explaining to him the difficulty I've had, we decided to cancel the deal. For ease of tuning, I recommend this goes on a Tacoma engine, NOT a T100 engine. The unit has just been sitting in my garage and I really need to sell it!
I've decided to try forums to get this sold, and of course I'm listing it on the Marlin board for first grabs before I list it on Pirates and TTORA.
I have invested nearly $3,000 in everything included here. NOT TO MENTION my time, labor costs, and small parts here and there. The basic kit new is over $3,000 and the 5th injector kit cost me $600. The additional pulleys and spare Toyota parts I have also acquired came at a cost. This is a GREAT chance to pump 50% more power (verified by Alpine) out of your Tacoma, 4Runner, or T100 at a great price!
Included is the following:
  • Alpine Supercharger
  • Compatibility Parts
    • 8-Port Cylinder Manifold for 1995-99 engines
    • 4-Port Cylinder Manifold for 2000-2004 engines
    • Throttle Body Manifold for 2RZ engines
    • Throttle Body Manifold for 3RZ engines
    • 2RZ Manifold Brace
    • 3RZ Manifold Brace
  • Alpine SC Piggy Back ECM (currently programmed for a 1995 Tacoma)
  • Alpine SC Piggy Back ECM wiring harness
  • Alpine 5th Injector Kit
    • Alpine 5th Injector Computer
    • Alpine 5th Injector High Pressure Fuel Line
    • Alpine 5th Injector Wiring Harness
  • 3 Different Boost Settings
    • 2 PSI Stock TRD Steel Pulley (15% power increase)
    • 5 PSI Alpine Aluminum Pulley (35% power increase)
    • 8 PSI Alpine Aluminum Pulley (50% power increase)
  • New Genuine Alpine Boost Recirculation Bypass Valve (modified mount)
  • Extra Replacement Parts
    • New Genuine Toyota Supercharger Oil (installed 500 miles ago)
    • New Genuine Toyota Supercharger Block off Plate
    • New Genuine Toyota Manifold Barb fitting
    • New Genuine Toyota Internal Shaft Coupler
    • New Genuine Toyota Fill Plug
  • Belt Tensioner Pulley
  • Belt Power Steering Routing Pulley
  • Included Documentation
    • Official TRD Installation Guide
    • Official TRD Belt Routing Guide
    • Official Alpine 5th Injector Wiring Diagram
    • Official Alpine 5th Injector Routing Diagram
Everything is in excellent working order. I have owned this unit for over 2 years. I am the 3rd owner of this unit. It was originally used in Colorado.
Everything included above is pictured below. If you have any questions, please do not hesitate to ask. I don't think I need to describe much what this is, so I'll let the pictures do the talking:
Here is it installed in my truck:
Here is the unit itself, currently setup with the 8-port manifold and with the 8-PSI Alpine aluminum pulley:
Here is the brand new Genuine Alpine Boost Recirculation Bypass Valve. Please note the mount was damaged when I received the unit and I have repaired it with a very reliable zip tie setup. The valve functions perfectly and has NEVER moved from it's mount. You can see it is properly mounted flush with the bracket. The valve only pulls, it doesn't push, so this is a very dependable solution.
Here are pictures of the installed Alpine 5th Injector parts:
Here is the Injector harness and the high pressure Alpine fuel line:
Here is the Alpine Supercharger Piggy Pack ECM (top) and the Alpine 5th Injector Driver ECM (bottom) with both wiring harnesses:
Here are the additional TRD Steel 2 PSI (left) and Alpine Aluminum 5 PSI (right) pulleys:
Here is the Alpine Aluminum 8 PSI pulley currently installed on the Supercharger:
Here are the two TRD Power Steering Pulley Adapter (right) and TRD Tensioner (left) pulleys:
Here is the Genuine Toyota replacement internal shaft coupler I have as a spare:
Here is the empty bottle of Genuine Toyota Supercharger oil. I've included this picture just to prove that I really did change the oil very recently.
Here are pictures of the 4-port late model 2RZ-FE and 3RZ-FE Cylinder Intake Manifold and the 2RZ Throttle Body Manifold:
And here is my custom Water/Alcohol Injector Nozzle installed and ready for use (nickel plated and filtered mist nozzle). This does not need to be used. It is an optional feature:
Closing notes:
The Supercharger is nice and tight, sounds perfectly normal at an idle and really lets it scream when you put your foot in to it. I had ZERO complaints with the functionality of the Supercharger: 8 pounds of boost comes in fast (around 2300 rpm) and even creeps upwards to 8-1/2 psi near red line.
Again, please be assured, this unit is solid, in good shape, I've had the manifold off while installing the 5th injector and the rotors look perfect, no scars at all. Nothing but air and fuel have passed through it.
Shipping Terms:
I am shipping from Fresno, California via UPS. If you need different arrangements, please let me know ahead of time. I am willing to drive within a 30 mile radius from 93727 to deliver.
The package should weigh around 50 pounds with everything. The unit itself weighs 35 pounds.
Payment Terms:
I prefer to meet in person with cash :gap: but will accept PayPal otherwise.
Stop wishing you had had more power and go big with a Supercharger at a great price!
« Last Edit: Mar 06, 2009, 08:33:37 AM by BigMike »
TacoStewie
  • Trade Count: (0)
  • Turtle Points: 4
  • Male Posts: 816
  • Member since May '06
Re: 2RZ 3RZ TRD SUPERCHARGER KIT + EXTRAS
« Reply #1 on: Jan 10, 2009, 06:47:42 PM »
sellin it to get a 3.4
4THEWKN
BigMike [OP]
  • Trade Count: (+1)
  • 511:1 Club
« Reply #2 on: Jan 10, 2009, 06:50:28 PM »
HA, if I wanted a 3.4 all I'd have to do remove 2 of my spark plug wires.
  • Trade Count: (0)
« Reply #3 on: Jan 10, 2009, 07:09:19 PM »
i'll post it over on TxTTORA for ya :bolt:
Cheesemaker
  • Trade Count: (+3)
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #4 on: Jan 10, 2009, 07:35:09 PM »
Does your wife know your using her good sheets to put your parts on??   :rofl2:
I thought there was a couple guys here, that was interested in it when you took it off your motor!   :headscratch:
BigMike [OP]
  • Trade Count: (+1)
  • 511:1 Club
« Reply #5 on: Jan 10, 2009, 09:03:48 PM »
I can post it there with no problems, but I wanted to offer it here first. :thumbs:
Thank you for spreading the word for me :biggthumpup:
Steve_925
  • Trade Count: (0)
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« Reply #6 on: Jan 10, 2009, 11:03:18 PM »
:drool:
do you accept IOU's
UA 342
STEAMFITTERS
BigMike [OP]
  • Trade Count: (+1)
  • 511:1 Club
« Reply #7 on: Jan 10, 2009, 11:23:05 PM »
only in the form of federal reserve notes :D
Steve_925
  • Trade Count: (0)
  • Male Posts: 1,876
« Reply #8 on: Jan 10, 2009, 11:33:27 PM »
dang...i guess only in my dreams
UA 342
STEAMFITTERS
wslytoy
  • Trade Count: (0)
  • Turtle Points: 36
  • Male Posts: 308
  • Member since Aug '02
« Reply #9 on: Jan 12, 2009, 08:26:33 PM »
dang... what a DEAL!!! Too bad I'm already spread so thing :(.
J Design
  • Trade Count: (0)
  • Male Posts: 2
  • Member since Jan '09
« Reply #10 on: Jan 22, 2009, 10:38:02 AM »
Hello,
Is this Supercharger still available?  I have a 1997 4 Runner 4wd, with a 2.7, auto, stock gears on 32" tires that needs a bit of a boost.
Thanks,
Jeff
BigMike [OP]
  • Trade Count: (+1)
  • 511:1 Club
« Reply #11 on: Jan 23, 2009, 09:50:19 AM »
Hello,
Thanks,
Jeff
Please check your PMs :thumbs:
filipponeglen
  • Trade Count: (0)
  • Member since Feb '09
« Reply #12 on: Feb 07, 2009, 10:10:46 AM »
please email me my name is glen im VERY interested in your supercharger and i live in cali i can meet u somehwer my email is filipponeglen@yahoo.com thank you
BigMike [OP]
  • Trade Count: (+1)
  • 511:1 Club
Re: 2RZ 3RZ TRD SUPERCHARGER KIT + EXTRAS [SOLD!]
« Reply #13 on: Mar 06, 2009, 08:34:04 AM »
Thanks to everyone's feedback -- this baby has been SOLD!!! :thumbs: :greengrin:
Steve_925
  • Trade Count: (0)
  • Male Posts: 1,876
« Reply #14 on: Mar 06, 2009, 08:37:23 PM »
I'm jealous of whomever bought it
UA 342
STEAMFITTERS
NorCalToy
  • Official Super Badass
  • Trade Count: (0)
  • Turtle Points: 77
  • Male Posts: 2,472
« Reply #15 on: Mar 06, 2009, 08:41:10 PM »
so can i ask why you pulled it off?
:flamer: IFS
  • Trade Count: (+1)
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #16 on: Mar 06, 2009, 09:41:40 PM »
Wasn't designed to work with the particular truck's engine he transplanted I believe.
BigMike [OP]
  • Trade Count: (+1)
  • 511:1 Club
« Reply #17 on: Mar 09, 2009, 07:31:42 AM »
Bingo
Last post Sep 02, 2006, 10:42:17 AM
by Geno
Last post Sep 19, 2007, 03:15:37 PM
by hudlenutz
Last post Jan 12, 2009, 12:46:08 PM
by eazy
Last post Oct 11, 2012, 07:36:58 PM
by GJToyotabug
Last post Jan 21, 2015, 05:57:56 PM
by 95xtracab
