Author Topic: TIMING??  (Read 3227 times)
SLIVER
  • Male Posts: 503
  • Member since May '06
  • ))--SLIVER-->
TIMING??
« on: Jan 06, 2009, 07:57:12 AM »
Hey guys, I just got done building a 22re. I put the engine builder crawler cam in it (.261 I think) bored .20 over. I am a novice at all of this and so I thought I'd ask you guys. What do you set the timing at. My chilton said advance it 5 degrees, so that's what I did for now. I have heard with the bigger cam you need to set the timing different.
What do you guys think that I should set it at???
I haven't driven the truck much since the engine swap, however it seem to run smooth right now. Just wondering if you guys think that I should change it or leave it where it is.
Thanks a ton.
))--SLIVER-->
))--SLIVER-->
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
Re: TIMING??
« Reply #1 on: Jan 06, 2009, 03:00:08 PM »
I time my stock-cammed 22re at 8 degrees........
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
Re: TIMING??
« Reply #2 on: Jan 06, 2009, 09:16:14 PM »
5 is stock. more advance is more power, less fuel economy, and possibly pinging. I loved running about 12*-15* but I couldn't run it all the time. 8* made more power than stock and was still happy with regular fuel.
edit:grammatical error
« Last Edit: Jan 06, 2009, 10:35:53 PM by Duffil »
Re: TIMING??
« Reply #3 on: Jan 06, 2009, 10:07:18 PM »
time the cam straight up, ie  on the mark
distributor timing is 5 degrees with t1 and e terminals crossed,
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: TIMING??
« Reply #4 on: Jan 07, 2009, 08:56:14 AM »
I timed the cam to the mark, and set the timing at 5 deg. with the terminal jumpped. Glen do you think I should advance the timing?? The guys above said around 8 deg will give me more power with this cam. What do you think? Should I leave it where it is or advance it??
Thanks.
))--SLIVER-->
))--SLIVER-->
  • Turtle Points: 1174
  • Male Posts: 5,057
  • Crawlin with Marlin
Re: TIMING??
« Reply #5 on: Jan 07, 2009, 12:13:52 PM »
I thought that advancing the timing effectively leaned out the fuel mixture and resulted in better fuel economy?  :dunno:
My 4Runner has a mild cam and likes premium fuel even with the timing in the 5-8 degree range.
Re: TIMING??
« Reply #6 on: Jan 07, 2009, 12:57:10 PM »
I timed the cam to the mark, and set the timing at 5 deg. with the terminal jumped. Glen do you think I should advance the timing?? The guys above said around 8 deg will give me more power with this cam. What do you think? Should I leave it where it is or advance it??
Thanks.
))--SLIVER-->
play it by ear and see what results you get,  8* on your truck might not work as well as another truck does on 5*  or even 12*
22RE and 22R's are very different,  i have mine at 12* then add the vacuum advance and centrifugal  i have about 34* total
83MT
  • Turtle Points: -23
  • Member since Jun '08
Re: TIMING??
« Reply #7 on: Jan 07, 2009, 01:40:29 PM »
Wow! I'm going to advance my timing a bit and see what that does for my fuel economy. I'm at around 6*, and I'm up around 5,000 ft so I think advancing it a bit may help. We'll see.
Zach
I like Yotatech
SLIVER [OP]
  • Male Posts: 503
  • ))--SLIVER-->
Re: TIMING??
« Reply #8 on: Jan 07, 2009, 01:57:01 PM »
Cool, thanks Glen.
))--SLIVER-->
))--SLIVER-->
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
Re: TIMING??
« Reply #9 on: Jan 07, 2009, 08:00:54 PM »
on my truck, i get less mileage when I advance it.
  • Male Posts: 5,057
Re: TIMING??
« Reply #10 on: Jan 07, 2009, 08:32:57 PM »
http://www.rodandcustommagazine.com/techarticles/0604rc_ignition_timing/index.html
According to this economy is linked to a lean fuel mixture and not directly to timing.  It also states that a rich fuel mixture will develop maximum power with less advance than a lean fuel mixture will.  It's all a balance and the optimal timing is determined by the fuel mixture.
peacesells
  • Turtle Points: -17
  • Male Posts: 791
  • Member since Jul '08
  • motley lou
Re: TIMING??
« Reply #11 on: Jan 07, 2009, 08:57:51 PM »
Timing on my 85 efi is around 20(w/jumper) with no pinging at 7000ft on 89 octane 15-30 degree air temp, 16(w/jumper) at 1500ft and 87octane 40-65 air temp is nice and peppy. 5 runs ok at idle, but has no power... 18-20 at 1500ft misses at idle. my 84 carb pings like a mofo after 10 on 87 octane at 1500ft
this my man lysol, fresh out the joint
peacesells
  • Male Posts: 791
  • motley lou
Re: TIMING??
« Reply #12 on: Jan 07, 2009, 09:03:07 PM »
and by the way, more advanced timing = more efficiency meaning more power per unit of fuel = better power per unit of fuel used(unchanged by initioal timing). you want to run the maximum amount of timing possible with no pinging whatsoever, unless you live at a high elevation and drive the truck at a lower elevation occasionally, then leave it dialed back (retarded a little). I go about 1/2 degree per 1000ft elevation. remeber, air at lower elevations is denser, more atomospheric pressure..
Timing
Last post Apr 19, 2004, 05:28:29 PM
by YotaYota
Last post Dec 29, 2005, 06:38:12 PM
by 79coyotefrg
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post Sep 14, 2008, 08:23:38 PM
by toyotamobing
Last post Nov 29, 2008, 07:02:41 PM
by 79coyotefrg
