X Today at 08:39:14 PM Ellsonsyota – how do you sart a thread?X Today at 08:38:26 PM Ellsonsyota – so after all i did i got to do it? they said to allpy some form of silicon to the timing cover and i kinda didnt want to but did in the end. so know i got to take out the oil pan so should i get some form of gasket to be aplyed instead of the silicon?X Today at 08:37:56 PM 79coyotefrg – you should save this i'm telling you, or start a thread here on MarlinX Today at 08:37:25 PM 79coyotefrg – you DO NOT have to remove the driveshaft or front axle shaftsX Today at 08:37:02 PM 79coyotefrg – go look under the front of your truck, theres a small cross member type thing in front of the differential, it bolts to each side of the front end and a big bolt into the diff mount, that needs to come out, then the other LARGE diff bolt, then you can lower the diffX Today at 08:35:26 PM 79coyotefrg – its a bit of a pain, but all you need to do is pull 3 bolts and a cross member thing and the diff will lower down enough to pull the oil pan without taking everything outX Today at 08:33:53 PM Ellsonsyota – srry food lolX Today at 08:33:38 PM Ellsonsyota – ye sand they say if you dont ahve a 4 in lift its a pain to get the oil pan out. is that true?X Today at 08:33:22 PM 79coyotefrg – Ellson, you still with us??X Today at 08:31:49 PM 79coyotefrg – i dont know WHY that popped into my mind
Started by YotaYota Engine
Started by 1Bad4Runner General 4WD Discussion
Started by RustyToy Project Research and Build-Ups
Started by wrenchtech Toyota Pickup/4Runner Tech 1979-95
Started by toyotamobing Parts Wanted
