Author Topic: 1990 toyota 4x4 pickup 22re diferential breathers?  (Read 3974 times)
mlatrella
  • Member since Oct '08
« on: Dec 30, 2008, 08:17:10 PM »
 My front and rear diferential(can't spell that) breathers are not rubber hoses, they are little valve thingys at the top. Are they some kind of one way valves or something like that? I've been going through water deaper then those valves and it worries me. any thoughts or suggestions would be apprieciated, thanks.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
SEARCH.
that said, run in a hose barb and run hose up as high as you can.
mlatrella [OP]
how do the valves come out?
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
well first pull the head, then you compress the retainer and pull the keepers out, and the retainer and spring come out and the valve will drop out of the head.
oh wait...there are no valves on a differential. sorry I was cornfused. ::)
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
With a wrench, righty tighty, lefty loosee
they arent valves they are simple breathers, they are NOT one way, so you need to check your differentials for water contamination (looks like a milkshake)
ive found the rear brake lines can be used to make a poor mans extended breather, (they have a male fitting on one end and female on the other)
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
Once you get them out you can use a gas(propane) barbed fitting.  I can't remember the the part#, but if you take in the valve you can just match it up.
You can also re-use the oem fitting, just remove the cap, push the breather line down over the bolt section and secure the hose w/a hose clamp.
93tonkatoy
  • Male Posts: 463
  • Member since Jul '07
3/8" air hose works good for the lines, just make sure you route it away from your exhaust. If you still have the LSPV attached, you can zip tie the hose to the arm about mid way up the arm, then run it up into the fender. I would also suggest running the line to the front of the bed, instead of the tail light, because entering and exiting a hole, the front noses down going in and the rear dips down when coming out.
SAVE TELLICO post 491
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
Last post Dec 22, 2006, 07:43:40 PM
by yota_krawler
Last post Sep 13, 2007, 07:37:21 AM
by bolus131
Last post Apr 27, 2008, 08:51:49 PM
by 51504ROCK
Last post Oct 28, 2008, 01:55:48 PM
by LOL @ IFS
Last post Jul 08, 2010, 02:38:46 AM
by mcphrawg
