Correction: '89 - '94 rear springs are not 3" wide. They use 3" u-bolts because of the steel and rubber "spring isolator" that wraps around the spring pack. The springs themselves are 2.5". The spring isolator can be removed (should be removed when modifying the pack), and the smaller u-bolts can be used with the matching lower plate, or use a u-bolt flip.
Started by toymachine Engine
Started by kneedownnate Parts For Sale
Started by unclejpl4x4 Parts Wanted
Started by johnyreb69 Project Research and Build-Ups
Started by David Parts Wanted
