Author Topic: engine replacement question  (Read 2137 times)
coelho69
  • Member since Oct '08
« on: Dec 17, 2008, 08:07:39 AM »
i came across a rebuilt block and head from a 85 thru 95(i believe) Toyota with the oval exhaust ports,my question is if i can installed it into a 83 pickup and reuse
my intake and oil pan, fuel pump and all the other part's, it a bare block with head but it's rebuild with bigger pistons and the head has bigger valves and a
RV cam and it's ported and polished, the price is great to(free)
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
Re: engine replacement question
« Reply #1 on: Dec 17, 2008, 08:24:35 AM »
no you can't to my knowledge
johnny916
  • Member since Mar '08
« Reply #2 on: Dec 18, 2008, 03:29:56 PM »
if your is a late model, whitch it means you have a 22R, then yes you can.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #3 on: Dec 18, 2008, 03:42:28 PM »
he can use his early model intake on it?
Hawk Thor
  • Turtle Points: 5
  • Male Posts: 112
  • Member since May '08
« Reply #4 on: Dec 19, 2008, 07:43:36 AM »
Buy a blown 22RE and strip it to get the things you need. You can then sell what you donīt need and scrap the rest.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Dec 19, 2008, 08:59:32 AM »
yes  it will all bolt right up,  the only difference might be the center coolant port but if the gaskets match your golden
« Reply #6 on: Dec 19, 2008, 09:01:58 AM »
for what he is wanting to do, YES HE CAN
he's not swapping a head  or block, he is swapping BOTH
coelho69 [OP]
« Reply #7 on: Dec 19, 2008, 09:10:45 AM »
SO THE INTAKE, VALVE COVER AND OIL PAN FROM MY 83 22R SHOULD BOLT TO THE 85+ 22R?
I KNOW THE HEADER I WILL HAVE TO BUY A NEW ONE BECAUSE OF THE PEAR SHAPPED PORTS
THE ONLY DIFFERENCE THAT I CAN SEE IS THAT THE NEW BLOCK IS ABOUT 3MM SHORTER IN HEIGHT
THAN MINE
THANKS FOR THE HELP GUYS!!!
« Reply #8 on: Dec 19, 2008, 09:21:07 AM »
yes, it should all bolt up, assuming the 85  was a 22R  and not 22RE
is the header a after market ?? if so it will probably be ok also
coelho69 [OP]
« Reply #9 on: Dec 19, 2008, 10:11:32 AM »
THE 85+ IS STAMPED 22R ON THE SIDE OF BLOCK
I HAVE AFTERMARKET HEADERS BUT MY HEAD IS ROUND PORTS AND THE OTHER IS PEAR SHAPPED, I WILL TRY IT
THANK'S FOR ALL YOUR HELP
Last post Apr 27, 2008, 08:33:24 PM
by Cheesemaker
Last post Aug 12, 2010, 04:06:30 PM
by blackSR5
Last post Feb 09, 2011, 09:35:14 PM
by yotaneck13
Last post Oct 21, 2014, 09:38:32 PM
by zippo
Last post Dec 28, 2015, 07:23:31 PM
by Noofed
