Author Topic: FULL WIDTH vs TOYOTA AXLES????  (Read 5274 times)
IrieKidinCal
  • Turtle Points: 12
  • Male Posts: 180
« on: Nov 29, 2008, 05:32:12 PM »
Im in the process of getting a new crawler. The truck has toyota axles with bobby longs in the front, running 37 bfg's.  I plan on running a taller wider tire aprox 37x14.50 17.  What would be stronger running 44 in the front and a 14bolt rear?  Can anyone suggest anything as far as input?  So is a 44 stronger than a toyota w/ bobbys??  or should I step up to D60's?  Please PM or let me know what you guys are thinking??  THAKX :beerchug:
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: FULL WIDTH vs TOYOTA AXLES????
« Reply #1 on: Nov 29, 2008, 05:43:48 PM »
toy front with longs is stronger than a 44, if u got the money go with 60/14 bolt, unless u are just looking for full width, dont waste the time on a dana 44
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
« Reply #2 on: Nov 29, 2008, 07:39:20 PM »
i would do a 60front and a 14bolt or d70 rear
Thomas P
  • Turtle Points: 109
  • Male Posts: 3,092
  • Member since Feb '06
« Reply #3 on: Nov 29, 2008, 11:03:14 PM »
if your only running 37"s go toyota with 30 spline longs and longs hub gears, beef up the knuckle studs and you should be fine, stay light stay cheap, keep it yota........
« Last Edit: Nov 30, 2008, 08:47:29 AM by 1985efiyota »
'14 Camry SE
SCX10 Honcho on roids!
Thomas P
  • Male Posts: 3,092
« Reply #4 on: Nov 29, 2008, 11:05:25 PM »
according to bobby longs chart the 30 spline yota axles are comparable to a stock 60, or am I misreading the chart?
'14 Camry SE
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2147
  • Male Posts: 2,339
  • RIP Kyle
« Reply #5 on: Nov 29, 2008, 11:13:55 PM »
or u can get alloy axles and be legit.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #6 on: Nov 30, 2008, 05:25:04 AM »
Full width, 60's front and rear, or do it a little cheaper with a T100 rear.
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #7 on: Nov 30, 2008, 06:21:27 AM »
FJ80 Axles aren't quite full width but they're about 7" wider than the standard solid mini axle.   You can get longs for the front of it too, which are bigger and stronger than the mini's and they came standard with the high pinion 3rd.   The rear 3rd is unique to the FJ80 but it is a fill floater from the factory.   If you look hard enough you can find ones with factory diff locks.
al76
  • Turtle Points: 7
  • Member since May '08
« Reply #8 on: Dec 01, 2008, 02:24:39 PM »
For some reason ive had an itch for a full width too but i just bought some longs  :smack:
F**k Idacurt
solar86yota
  • Male Posts: 296
  • Member since Mar '08
  • Solar-Rockin' the IFS till it dies!(Then it sits)
« Reply #9 on: Dec 01, 2008, 03:25:58 PM »
Keep it Yota ALL THE WAY!!!!
By the time I get the money for an SAS I'll be 65 at this rate!
camoyota
  • Male Posts: 188
  • Working to Play
« Reply #10 on: Dec 02, 2008, 03:04:36 PM »
put a tundra rearend in it
Last post May 26, 2006, 12:13:35 PM
by pickemup81
Last post Oct 30, 2008, 10:16:39 PM
by muddytaco
Last post Dec 23, 2010, 04:39:08 AM
by Rocksurfer
Last post Feb 20, 2011, 10:55:47 AM
by GreenYoterKrawler
Last post Nov 11, 2011, 09:41:18 PM
by wakkjobb
