Get rid of the 3.0 its a garbage motor swap a chevrolet 4.3 or do somthing diffrent and try putting in the 5VZFE
In your opinion please tell us what is wrong with the 3.0 and how long you have had one. I have been running one for over thirteen years and have yet to have a problem with it. Yes they are not the fastest thing, but neither is a 22r. Yes there were HG problems with them, I had mine done right after I got it thirteen years ago and have not had a problem since. They are a bit harder to work on, but you learn to adapt.What kind of problems did you have with the one you owned. If you tell me you have not had one then it is hearsay which to me means it is the byproduct of hay which comes out the back ends of male cows which are Bulls.
I can't decide on the thing. I wanna work on it but I also wanna take a break from wrenching now that the crawler is done. I think I'll lay off the projects for a while and push the thing in the side yard once the old 3.0 is out
I got the old motor out now. Next to come is the tranny and t-case. I got this idea of finding a complete 3/4 ton chevy pickup like a late 70's and swapping all the drivetrain on the Runner. I got a nice 4 bolt main 350 sitting in my garage and if I run that I wanna take out all the toy drivetrain. Run a 44 and 14 bolt, leaf sprung all the way around for simplicity, do a small body lift for clearance, install a 350/th350/205 or 208, cut down the chevy driveshafts to length. Run like 4.5 inches of backspacing with bigger fender flares and it just might be legal. I'm not a big fan of the 3.0 after having to pull one. And all this IFS garbage needs to go. I'll vut and hack away the inner fender flares so I got room to work. Mount all the bs on the firewall.
Started by yarddog General 4WD Discussion
Started by Northern Runner Engine
Started by S14 General 4WD Discussion
Started by blackSR5 Engine
Started by Siringo Toyota Pickup/4Runner Tech 1979-95
