How To Polish A Turd (72 Hilux)
Started by GrenadedToy, October 13, 2008, 09:14:13 PM
89sastoyo
yeah it is but still in the end i think you'll like the looks a lot more and less hackin on the bed pluss you'll loose some lift puting it on the back of the frame.
as far as your front goes we need to figure out how to lower it but move your axle forwards maybe try those sky shims that move it or re-drill the center pin a little cause its a monster lol
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
www.4crawler.com also has those relocation shims....
however, wont those add like a half inch block to the height?
iNfErNaL
Quote from: GrenadedToy on April 15, 2009, 11:27:42 PM
Yeah I know I realized that when I set weight on the axle. Ill have to re-extend my frame rails. The shackle hanger won't go back any farther.
You know , it's really not as bad of an angle as people think , the way it's set up will allow for more droop . I personaly would keep it the way it is . . . . But that's just me .
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
iNfErNaL
Quote from: GrenadedToy on April 15, 2009, 10:25:01 PM
Got all my tires and beadlocks mounted :cool:
Dude , your truck is coming out bad ass ! ! ! ! . I really dig the way it looks . Great job with it so far .
GrenadedToy
Quote from: iNfErNaL on April 17, 2009, 01:41:22 AM
I think ill run it then and see how the taco rears flex. That way it will be one less thing to do on the already huge list.
Quote from: iNfErNaL on April 17, 2009, 01:45:14 AM
Thanks man!
twistedtoy92
87pickup
If you wanted to move the rar shackle hanger back then why not do it like the Marlin Crawler formula f toy? The you wont need to extend the frame rails. Looks good by the way.
GrenadedToy
Painted the grill Flat Black.
Next to my buddies Samurai that is on Toy axles and 36's.
Floor Frame.
Skinned. Waiting to tub the inner fenders..
89sastoyo
It looks good for sure the black grill looks better to:).
I think im pickin up that hydro assist tonight ill call you when i get back maybe come check it out or somethin
92 2wd DD
first gen cab
ajordan1975
Steve_925
props on the floor. that stuff sucks to have to do
UA 342
STEAMFITTERS
89sastoyo
lookin good just drove by saw the cab off let me know if you need help gettin it back on
92 2wd DD
first gen cab
46&2
toyotanner
i think its getting to close to being finished lets tear it apart and start over :gap:
89sastoyo
Quote from: toyotanner on April 27, 2009, 10:38:28 PM
That was cold brother.
92 2wd DD
first gen cab
Ramrod
you can redrill the spring perches to move your axel forward 1.25" and then rebuild the front spring packs with flatter springs to get that thing sittting lower
GrenadedToy
I guess this thread is due for an update.
Heres my steering shaft.
Top part is from a mazda b2200 with adapter to hilux steering column. Lower Part is Toyota shaft.
Rear crossmember capped and added a D-Ring
Front Axle shave with creeper gussets, and truss.
Exhaust. :greengrin:
Still got plenty left to do till the fourth. I better get to work.
89sastoyo
you did work on that axle looks good for sure. Ill hit you up when im off work tonight and see if i can find a throttle cable.
92 2wd DD
first gen cab
thegoofster21
hey bud can i get some info on the samuari please. thanks man
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
toyotanner
Quote from: thegoofster21 on June 10, 2009, 07:43:45 PM
thats my roommates sami that i was talking about its on toyota axles, 36's, yj springs, 4.?:1 tcase, propane.
anything specific you need to know?
toyotanner
you need to build your leaf packs so i can get some from you :gap:
Slolyfe
You'll never take me alive
GrenadedToy
ninja turtle
this thing is sweet. im gunna pull my carpet today... god i hope i dont find what you did.
thegoofster21
Quote from: toyotanner on June 10, 2009, 09:19:15 PM
year jy spings and how long are they. thanks
jmoffroad.com
GrenadedToy
#148
Heres A few more updates.
Traded my ARb, aussie, and 5.29 thirds for some 4.10s that are welded with a lock right. I didnt feel like dumping another 600 into those diffs to get them fixed :shake:
Stuff left to do:
-Front and Rear Drivelines
-Wiring
-Seam seal the floor
-Front Axle together
-Bleed Clutch and Breaks
-Work out all of the kinks
Heres the pics..
Found A brand new in the box painless 8 circuit harness for $150. Saved me $120 buying it new.
Drive Side Tub
Passenger side tub
Rear Axle is together minus One caliper
Hood Vent off a 72 Celica @ Upullit
Ill get a better shot of the valve cover soon
Tercel Wagon Seats
Gauges
They light up as 6 other colors tooo :driving:
toyotanner
#149
DAMMIT  :outtahere:
