Author Topic: 4WD not shifting out to 2WD.  (Read 1874 times)
Jaysen
  • Turtle Points: -20
  • Male Posts: 773
  • Member since Mar '08
« on: Sep 21, 2008, 10:06:29 PM »
I have a 95 toyota ext p/u 22re. I took it hunting over the weekend and use 4WD I can't shift from 4lo or hi 4 to 2WD unless I turn off the engine and then shift to high 2 just want to know if its normal. My truck as factory manaul hub. need help asap.. :confused:
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
Re: 4WD not shifting out to 2WD.
« Reply #1 on: Sep 22, 2008, 09:09:57 AM »
did you try backing the truck up a few feet ??
YotaJosh
  • Male Posts: 499
« Reply #2 on: Sep 22, 2008, 09:39:41 AM »
I usually can't go from 4HI to 2HI unless I'm rolling and loading the drivetrain with a few RPM's. I usually let off the gas, and the shifter moves easily.
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
Yota Up
  • Turtle Points: -4
  • Member since Feb '06
« Reply #3 on: Sep 22, 2008, 12:15:05 PM »
Go in reverse and hit the brakes hard to come to a stop quick, take the load off.  Try it.  If no worky, go forward and slam on the brakes, and try again.  Repeat until it works.
Jaysen [OP]
  • Male Posts: 773
« Reply #4 on: Sep 22, 2008, 10:18:24 PM »
Thank you. I'll try that hopefully it work.
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #5 on: Sep 24, 2008, 06:42:06 AM »
most of the time ya gotta be rolling back or fwd to get it to take the load of the truck and then it will slide right into 2 hi
IF YOUR LOOKING OUT THE FRONT OF YOUR 4X4 AND YOU CANT SEE THEN JUST TURN ON YOUR WIPERS. BUT THEN THINGS GET ALL MESSED UP LIKE IN LIFE.
WHEN YOU GET TO THE END OF YOUR ROPE JUST THINK THAT ALONG TIME AGO  YOU WERE THE FASTEST LITTLE SWIMMER TO THE EGG
08:55:22 PM BeccaLoo24 – i like to screw things
$99 scratch and dent drill press has drilled more holes than Ron Jeremy.
http://board.marlincrawler.com/index.php?topic=48342.0
[img]http://bo
DFWFO
  • Male Posts: 163
  • Member since Sep '08
« Reply #6 on: Sep 24, 2008, 07:52:22 PM »
try it in a steep driveway, thats what i have to do.
All Im lacking is a flux capacitor and the ability to hit 88.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #7 on: Sep 24, 2008, 10:38:34 PM »
What we are telling you to do is caused because the shift collars have a 2 degree female taper and the mating shift hubs have a 2 degree male taper. This design helps prevent the t/case from walking out of gear however, is not uncommon for the mating parts to get locked togeather. This condition should get better in time as you use the t/case more.
Dr.Maxwe001
  • Male Posts: 627
« Reply #8 on: Sep 25, 2008, 05:35:40 AM »
[img]http://bo
shifting Q
Last post Jul 08, 2005, 05:43:56 PM
by Uncle Jesse
Last post Feb 19, 2010, 11:02:20 PM
by kneedownnate
Last post Oct 13, 2010, 06:21:15 PM
by BIG-T
Last post Apr 19, 2011, 07:25:10 AM
by weakyota91
Last post Sep 18, 2011, 12:04:11 AM
by tyesman
