Author Topic: 4WD not shifting out to 2WD.  (Read 1866 times)
Jaysen
  • Turtle Points: -20
  • Male Posts: 773
  • Member since Mar '08
« on: Sep 21, 2008, 10:06:29 PM »
I have a 95 toyota ext p/u 22re. I took it hunting over the weekend and use 4WD I can't shift from 4lo or hi 4 to 2WD unless I turn off the engine and then shift to high 2 just want to know if its normal. My truck as factory manaul hub. need help asap.. :confused:
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 4WD not shifting out to 2WD.
« Reply #1 on: Sep 22, 2008, 09:09:57 AM »
did you try backing the truck up a few feet ??
YotaJosh
  • Male Posts: 499
  • Member since Dec '06
« Reply #2 on: Sep 22, 2008, 09:39:41 AM »
I usually can't go from 4HI to 2HI unless I'm rolling and loading the drivetrain with a few RPM's. I usually let off the gas, and the shifter moves easily.
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
Yota Up
  • Turtle Points: -4
  • Member since Feb '06
« Reply #3 on: Sep 22, 2008, 12:15:05 PM »
Go in reverse and hit the brakes hard to come to a stop quick, take the load off.  Try it.  If no worky, go forward and slam on the brakes, and try again.  Repeat until it works.
Jaysen [OP]
  • Male Posts: 773
« Reply #4 on: Sep 22, 2008, 10:18:24 PM »
Thank you. I'll try that hopefully it work.
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
« Reply #5 on: Sep 24, 2008, 06:42:06 AM »
most of the time ya gotta be rolling back or fwd to get it to take the load of the truck and then it will slide right into 2 hi
[img]http://bo
DFWFO
  • Male Posts: 163
  • Member since Sep '08
« Reply #6 on: Sep 24, 2008, 07:52:22 PM »
try it in a steep driveway, thats what i have to do.
All Im lacking is a flux capacitor and the ability to hit 88.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #7 on: Sep 24, 2008, 10:38:34 PM »
What we are telling you to do is caused because the shift collars have a 2 degree female taper and the mating shift hubs have a 2 degree male taper. This design helps prevent the t/case from walking out of gear however, is not uncommon for the mating parts to get locked togeather. This condition should get better in time as you use the t/case more.
Dr.Maxwe001
  • Male Posts: 627
« Reply #8 on: Sep 25, 2008, 05:35:40 AM »
[img]http://bo
shifting Q
Last post Jul 08, 2005, 05:43:56 PM
by Uncle Jesse
Last post Feb 19, 2010, 11:02:20 PM
by kneedownnate
Last post Oct 13, 2010, 06:21:15 PM
by BIG-T
Last post Apr 19, 2011, 07:25:10 AM
by weakyota91
Last post Sep 18, 2011, 12:04:11 AM
by tyesman
