Negative arch?
Started by jrock, August 31, 2008, 05:51:14 PM
jrock
Well here's mine, show off yours.  :biggthumpup:
i cant, i jsut lifted my truck :)
befroe my lift though, i was about 1.5" away from the bumpstops
KDXSR5
holy crap, those are the worst I have ever seen. ever.
Mine from about a year or so ago:
and now with my custom pack:
Toymin8r
Looks like someone has been playin' Dukes Of Hazzard.   :gap:
88_Pathy
Quote from: KDXSR5 on August 31, 2008, 06:28:37 PM
From the pic your new pack looks like it is backwards.
94MtnYote
Marlin 1200LB clutch
KDXSR5
Quote from: 88_Pathy on September 01, 2008, 09:47:16 AM
No its going the right way
Quote from: durtyota on September 01, 2008, 09:55:22 AM
nice sock.
thanks, I figured it brought a new dimension to the normal truck pics that one usually sees.
Duffil
how about pics of what you are flexed on?
todd, yours is a stock pack, that's normal. OP's pack is flexed.
RTA
Here's mine:
So. Cal. ROCK BRAWLERS
jrock
Look at the wave
Quote from: Duffil on September 01, 2008, 11:45:49 AM
Sorry but no pic, I'll post my normal stance tonight.
88_Pathy
Duffil
ladies and gentlemen, i present: BUMPSTOPS
KDXSR5
hmm... this seems to be a foreign idea to me
:gap:
DTB
jrock
More failure to add hardware!
Slolyfe
You'll never take me alive
Slolyfe
lets try that again. What happens with too much negative arch!
Quote from: slolyfe on March 21, 2009, 11:12:37 PM
Wow I'd say next time put a longer second leaf in there to support the main..... That's what killed that one, negative arch, a bit of throttle and 5" of unsupported main leaf will bend every time. :gap:
Slolyfe
Volcom
Quote from: jkief86 on August 31, 2008, 05:51:14 PM
My stock springs on my 85 truck looked like that all the time, hell they were negative arched just sitting in the driveway :)
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
4x4yota
so what is being done to fix all this negative arch?
Current:
Sold:
jrock
KDXSR5
Quote from: 4x4yota on April 02, 2010, 04:41:54 PM
You have seen my fix :gap:
4x4yota
Quote from: KDXSR5 on April 02, 2010, 07:34:03 PM
that I have and I am prolly going to try it when I get time but not as much lift maybe 1" or less just enough to at least make them flat if not posative arch
Current:
Sold:
KDXSR5
Quote from: 4x4yota on April 02, 2010, 09:52:18 PM
They settled down to basically flat/stockish. The only lift the front of my truck really has is mostly from shackles. If you do try it the same way I did, and after it settles it still has too much lift, you can always remove a leaf.
4x4yota
ok cool I have the old set of leafs off the rear of my 4runner plus a set off the front that were heavily modified RUFs
got any currant pics of the leafs to see how they settled?
Current:
Sold:
KDXSR5
Quote from: 4x4yota on April 03, 2010, 12:00:18 AM
No, I will take pics once the truck is back together if you remind me. Right now it is sitting on jackstands. Really, you could use just about any long skinny leaf spring as long as it is the right width. Just mix and match until you get the height you want.
4x4yota
thanks for the advice I appreciate it... Ill prolly start tearing appart leaf packs monday and see what I can come up with
Current:
Sold:
KDXSR5
Picture with the weight of the truck on the springs. As you can see, the springs are almost flat. Most of the lift is from the shackle, and I have a bolt on add a leaf/ axle relocater deal in there too that provides a little lift and moves the axle forward a bit. If you would like more pics, let me know.
4x4yota
what type of plate do you have moving your axle forward Im looking to do the same also unless you want to sell me your truck so I dont have to copy I can just have it lol
Current:
Sold:
