I used 1.5 inch spacers to match my rear axle... but apperently that is incorrect according to the above post. Oops, guess I bought the wrong ones.
I have a '92 and did a sas on it with an axle from an '85 and was wondering if i could run the stock calipers on the '85 axle without wheel spacers. And when I get wheel spacers, to be even with the rear should i get the 1.5" or the 2" spacer? thanks
boggerrunner, where'd you get the 5/8's spacers, or did you make them yourself?
u can find them in some magazine for dirt track racing parts, can remember the name of it
if u want to use wheel spacers, u need the 1.5" spacers, if u want to do a cheap ifs hub/brake conversion, check out what i did.
Started by conflict Engine
Started by 85EFIYota Project Research and Build-Ups
Started by flat green yoda Newbie Questions
Started by WESTREN Newbie Questions
Started by samskmram New Member Check-In!
