Author Topic: using ifs calipers from a '92 on an 85 straight axle swap  (Read 8541 times)
yota8
  • Turtle Points: -9
  • Member since Apr '07
« on: Jul 03, 2008, 02:35:47 PM »
I have a '92 and did a sas on it with an axle from an '85 and was wondering if i could run the stock calipers on the '85 axle without wheel spacers. And when I get wheel spacers, to be even with the rear should i get the 1.5" or the 2" spacer? thanks
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
Don't you need 1.5in spacers to match the rear's width?
jonathan82toy
  • Turtle Points: 5
  • Male Posts: 502
  • Member since Mar '07
  • 1St Gens Rule!
 When you  put the 92 calipers on, run  1.25in spacers, 58in width front and rear.   :turtle:
What Is The Truth Behind The Magic Turtle Breeding Program?
S.S. More Powerful Than Superman, Batman, Spiderman And The Incredible Hulk Put Together.
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
I used 1.5 inch spacers to match my rear axle... but apperently that is incorrect according to the above post. Oops, guess I bought the wrong ones.
yota8 [OP]
  • Turtle Points: -9
alright thanks for the help.  One more question I am moving my steering box and wanted to know the easiest way of lengthening my steering shaft to my steering box?
flatbedtoy
  • Male Posts: 69
  • Member since Mar '08
I've got the same on my truck.
94 4wd pickup, SAS
95 2wd pickup
06 4wd 4 Runner SR-5
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
if u want to use wheel spacers, u need the 1.5" spacers, if u want to do a cheap ifs hub/brake conversion, check out what i did.
waskillywabbit
  • Male Posts: 133
  • Member since Oct '04
  • Tuscaloosa, AL
    • WabFab Off -Road LLC
You need 1.5" wheel spacers as the rear axle is 3" wider than the 85 SFA.
No reason you cannot run the stock disc brakes that were on the 85 as long as you have the solid rotors.  The 85 calipers and vented rotors won't work.
The easiest way to lengthen the steering shaft is to drill out the little plastic pins in the shaft so it will slide or you can lengthen it by getting some longer tubing and fabbing your own.
:yupyup:
ranchworks
  • Member since Sep '08
if you don't want to use any spacers,  use 85 landcruiser vented rotors, ifs hubs, ifs calipers.  calipers must be split apart and shaved 1/8th inch. to clear rotor.  caliper mounting holes must be drilled and retapped.
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
boggerrunner, where'd you get the 5/8's spacers, or did you make them yourself?
              -Ronald Reagan
kiyul4130
  • Brown Star Award
  • Turtle Points: 279
  • Male Posts: 3,265
  • Member since Jul '05
  • Turdburgalin since 1985
i have a 92 pickup and did that when i did my sas. i dont see why you would need to run spacers. people run them like stated earlier above, to match the width in the rear or be just a pinch wider than the rear. you using the vented rotors?
-kiyul-
ECV 7-11
KYOTA FOREVER
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
u can find them in some magazine for dirt track racing parts, can remember the name of it
BLACKDOG
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
cool, thanks!  :thumbs:
              -Ronald Reagan
WisconsinYota
  • Member since Apr '10
Good idea, but now isn't there a lot of stress on the two bolts between the rotor and hub?  The stock setup uses the six wheel studs as well as the two bolts to hold the hub and rotor together.
Maybe I'm not seeing the whole visual.  It's hard to tell from just one picture.
'87 Toy -  SAS, Marlin HiSteer, 5.29 Yukons, Welded Rear, Marlin Duals, Marlin 1600lb Clutch, 36x12.5" Super Swampers..Basic but functional (and expensive..)
wesley
  • Turtle Points: -1
  • Member since Mar '10
  • you gotta get a little mud on the tires
i feel that everyone is confusing you. this stuff is soooooo simple i dont understand why people make breaks and hubs complicated
jimmer009
  • Male Posts: 105
  • Member since Jun '10
  • good as used
I just did my sas last wekend. finished up and went to drive off and the front tiers were froze. I used all ifs except 82 landcrusier rotors. my calipers hit on the rimms and I had to buy spacers. mine to is a 92 and it was a 85 axel.
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
anyone ever find where to get that 5/8 aluminum spacer for the ifs hub mod at? I searched, ntohing
junya92toy
  • Turtle Points: -64
  • Male Posts: 1,500
  • Member since Nov '04
  • Drinking me beer
Last post Jan 02, 2004, 03:51:35 PM
by jvministries
Last post Sep 09, 2007, 08:23:42 PM
by 85EFIYota
Last post Apr 29, 2011, 04:46:13 AM
by 4RunnerChevy
Last post Feb 10, 2013, 09:28:43 PM
by Cheesemaker
Last post Dec 14, 2014, 04:19:57 PM
by samskmram
