It's called driveline bind, easy to get from 4Low to 4High and a pain to go from 4High to 2High.Try rolling/rocking back in reverse then shift.Mine does the same thing.
is the tranny in gear whne you try this? i have found my tcase doesnt want to shift for beans if the transmission is in gear
sounds like your clutch isnt releasing completely
i meant if tranny is in gear and i try to shift tcase, it doenst wnat to go... now if i toss the tranny in n then the tcase shifts a lot easier....the toyota system is not shift on the fly
ah, thats because you do not have your hubs locked in!
for 1 DO NOT TRY TO SHIFT INTO 4WD WHILE DOING 50 ON THE FREEWAY.
...drive forward slowly with pressure on the stick...it'll go.
what idiot would try to shift into 4 hi when the hubs are not locked
I may have missed it butt did anyone ask if front and rear tires are the same size?
Started by bigman Engine
Started by Moit88RNR Toyota Pickup/4Runner Tech 1979-95
Started by ohiofarmer Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by weakyota91 Engine
Started by tyesman Engine
