Author Topic: Mis-fire #3 Code: P0303  (Read 3611 times)
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« on: May 06, 2008, 07:25:09 AM »
I have a mis-fire on the #3 cylinder. 3.4L V6
I've changed the wires and plugs, what els could be causing it?
« Last Edit: May 07, 2008, 06:50:32 PM by MiniSimp »
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
Re: Mis-fire #3
« Reply #1 on: May 06, 2008, 08:04:12 AM »
What year is your 4Runner? Possible coil pack.
87 4Runner redo
MiniSimp [OP]
  • Male Posts: 5,120
Re: Mis-fire #3
« Reply #2 on: May 06, 2008, 08:06:58 AM »
Sorry, 2001
Tallchevy
  • Male Posts: 3,562
Re: Mis-fire #3
« Reply #3 on: May 06, 2008, 08:13:26 AM »
Do you have any codes? If so, what are the code #'s if you have them?
87 4Runner redo
MiniSimp [OP]
  • Male Posts: 5,120
Re: Mis-fire #3
« Reply #4 on: May 06, 2008, 08:29:29 AM »
I don't have the code number, but our shop mechanic ran it through the OBD code reader and it came up with a misfire on the #3 cylinder with 2 previous misfires on the #3 cylinder stored.
MiniSimp [OP]
  • Male Posts: 5,120
Re: Mis-fire #3
« Reply #5 on: May 06, 2008, 10:06:19 AM »
I'm going to try running some injector cleaner and see what happens.
Any recommendations for a good cleaner?
Re: Mis-fire #3
« Reply #6 on: May 06, 2008, 10:19:04 AM »
seafoam
Tallchevy
  • Male Posts: 3,562
Re: Mis-fire #3
« Reply #7 on: May 06, 2008, 10:31:42 AM »
Did you change the fuel filter? Check the fuel pressure. I worked on a Ford Mustake the other day that had a fuel injector sensor thingy go bad & it gave a misfire on #1 & #3.
87 4Runner redo
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
  • Member since Feb '08
Re: Mis-fire #3
« Reply #8 on: May 06, 2008, 10:35:51 AM »
Swap your coils and see if the miss changes cylinders. Chances are you got a coil going bad we've replaced a bunch of them for mis-fires.
Willy Mammoth
  • Male Posts: 4,252
Re: Mis-fire #3
« Reply #9 on: May 06, 2008, 05:37:04 PM »
:thumbs:  :yesnod:
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
Re: Mis-fire #3
« Reply #10 on: May 06, 2008, 09:44:43 PM »
I had a miss fire on our van and it was the spark plug boot had a crack in it.  New plug boots too~!
super22r
  • Turtle Points: -1
Re: Mis-fire #3
« Reply #11 on: May 06, 2008, 10:58:45 PM »
check injecter with volt meter/set it to ohm and measure the resistance and compare with other injecter
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
Re: Mis-fire #3
« Reply #12 on: May 07, 2008, 08:08:38 AM »
if he has to replace the coil it will come as a unit with a new boot
MiniSimp [OP]
  • Male Posts: 5,120
Re: Mis-fire #3 Code: P0303
« Reply #13 on: May 07, 2008, 06:27:36 PM »
Ok so the code is P0303 Misfire #3 cylinder is all it says.
Since I've replace the spark plugs and coil/wires then I think I'm down to 2 possibilities:
1. The coil hooked up to the computer on the PS of the engine is bad, but then I would think that 2 of the cylinders would be misfiring...???
2. The Injector on the #3 cylinder is bad, kinda makes more sense to me, but sounds like a PITA to change. Anybody know how much an injector costs?
Advice? Options? Ideas? Bacon?
« Reply #14 on: May 07, 2008, 06:58:10 PM »
i wish i could help ya  Kyle  but i have NO clue
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
Re: Mis-fire #3
« Reply #15 on: May 07, 2008, 07:03:07 PM »
this is about the best suggesrtion ive seen, seafoam wont help, its not a clogged injector
toyota has codes for injectors, a misfire is seperate. it is actually as simple as it sounds-#3 is not firing
check coil packs, all wires going to coils, make sure that if you swap em around you remember wheich is which,
toyota also will flag misfire if compression is abnormally low in a cylender
crawlerdan
  • Male Posts: 4,770
« Reply #16 on: May 07, 2008, 07:05:05 PM »
yep-bacon
MiniSimp [OP]
  • Male Posts: 5,120
Re: Mis-fire #3
« Reply #17 on: May 07, 2008, 07:06:16 PM »
Thanks. :yesnod:
Tallchevy
  • Male Posts: 3,562
« Reply #18 on: May 07, 2008, 09:02:33 PM »
An aftermarket injector is around $200.
Check the emmisions warranty from Toyota, maybe it's still covered  :dunno:
87 4Runner redo
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
« Reply #19 on: May 08, 2008, 07:45:28 AM »
Mini the injector is not as bad as it seems to change out. How did you realize the injector was bad? I suggest before you replace the injector go the local dealership i ask for a fuel injector service it is a pressurized can of cleaner you have to take the fuel pump loose and tie it into the line. It done wonders on my 3.4 but only problem is the tool to it is a dealer tool. Don't seem to  sound like a jerk but are you sure you actually working on cyl. 3. I've seen alot guys get the cylinders mixed up.
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #20 on: May 08, 2008, 07:55:45 AM »
I'm not sure it is the injector.
I'm going to try switching the coils first and test that.
I'm not sure which is cyl. 3, but I've got a book or two that I'm sure will help me out.
I'm hoping to start on it Saturday morning.
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
« Reply #21 on: May 08, 2008, 08:04:08 AM »
Cyl. 3 is the middle coil on passenger side. take a long screw driver and lay it on the injector and using your ear listen to it and compare it to the other injectors should hear it pulsing. if it is then it should be just clogged if it is the problem.
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #22 on: May 09, 2008, 07:22:49 PM »
Ok, so...I'm lost.
I switched my #3 coil with my #1 coil and now the thing runs like a raped ape! :driving:
The hope was that I would get a P0301 code (misfire #1) to determine that the coil was the problem. Now there is no problem, no stumbles, full throttle with a kick. :burnout:
I'm so confused. :dunno:
crawlerdan
  • Male Posts: 4,770
« Reply #23 on: May 09, 2008, 08:04:29 PM »
reset the computer by pulling the groung off the battery for 5 mins at least.
drive for a few days under normal conditions, check again
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
« Reply #24 on: May 09, 2008, 08:12:30 PM »
could have been a loose connection on that coil, causing misfire.
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #25 on: May 09, 2008, 08:45:07 PM »
Did that this afternoon.
Maybe
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #26 on: May 16, 2008, 06:12:10 AM »
I have good news!
got a mis-fire on the #1 cylinder!!! :_oops:
So that means the coil is deffinetly the problem. :yesnod:
Duffil, give me a call.
ROKTOY829
  • Turtle Points: 45
  • Male Posts: 191
« Reply #27 on: May 16, 2008, 06:19:02 AM »
Cool beans nothing major it seems
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #28 on: May 16, 2008, 07:14:33 AM »
don't worry bro I still have it.  We can grab it whenever.
MiniSimp [OP]
  • Male Posts: 5,120
« Reply #29 on: May 16, 2008, 07:37:31 AM »
Gimme a call from work when you get a chance, I'll pay for it now, pick it up at 6am tomorrow morning.
Last post May 14, 2005, 05:02:38 AM
by 79coyotefrg
Last post Jan 17, 2006, 01:29:01 AM
by dov'd85
Last post Jan 27, 2006, 02:28:18 PM
by BLACKDOG
Last post Mar 29, 2008, 06:38:31 PM
by skipnrocks
Last post May 01, 2008, 03:01:46 PM
by 79coyotefrg
