Relentless Runner Build
Started by slabcs, April 29, 2008, 10:44:52 AM
slabcs
Sweet dude, so yours is getting there too.  First trip on it will probably be the Rubicon in September.
Wanna race to dual cases and bumpers?
Relentless
Skim
How much cutting of the fenders are you going to do to allow those 37s to fully flex ?
I am about to install the same 4" marlin front kit and I'd like to run 37s with minimal cutting if any.
85 Hilux Long Bed - For Sale
slabcs
No trimming necessary.  They have plenty of room, already flexed it out to check.  The rear will need a lot of work, just haven't gotten motivated enough to do it yet.  The 37's do hit the front leafs when turning either way though.  I need to find 17x8's that aren't 4.5" BS...
Relentless
864runner
well i think it is still going to be a while till dual cases and bumpers/sliders but we will see, it just depends on work at the shop, the more work the more money, and its starting to pick back up so maybe sooner than later.  but if you are going to the rubicon in september i hope i'll have it together and maybe go wheelin
toyotamobing
hey if i can get my stuff running again and duals or atleast tcase gears im down to go again...as long as its not snowing or raining!!! are you going to the round up?
1996 Tacoma 3rz auto 4x4
1993 Jeep XJ 2 door 5spd 4cyl 4x4
1996 Dodge 3500 12V 5spd 4x4
@alteredegospeedshop
MAKING A SLOW TRUCK GO FAST SINCE 2003
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
www.polyperformance.com
slabcs
I don't know. I think that's the weekend I move into my dorm.  I'm not sure.  If I can't make it I'd be down to do Rubicon the weekend before.
Also, I made it up the grade yesterday in the Relentless Runner.  Haha.
Relentless
toyotamobing
haha like from slo to atown? or the offroad part of the grade?
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
slabcs
Atascadero to SLO, I went back on the 41 because I didn't feel like doing the entire northbound grade in second gear.  I need to get motivated and finish this thing up.
Relentless
toyotamobing
um yea!!! i think adric might beat you on that race to bumpers and duals...
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
864runner
I don't know i'm low on funds, thats the only thing holding me back.  if i had the cash i would have it all here now :). but that is with anything lol, money money money.
4RunnerKid
yeah Russ... quit your slacking and finish this thing up
toyotamobing
that should be some motivation for you!!!!
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
slabcs
Update, kinda.  Shock towers and 14" Bilsteins are in.
Plated with some 3/16's.
Moving my rear shackle hangers back.
Those things suck to remove for sure...
2" back with the new ones.
Paint that I never give time to dry.
Done.
It evened out the stance a bit, and it seems like I have a lot less body roll while turning.  Also the 37's don't munch the body on every turn/speedbump now.  Still waiting for those springs to settle, they've only got a couple hundred street miles on them so far.
And I figured out I'm getting 15 mpg with the 4.10's and 37's, haha.  Not bad.
Relentless
DTB
Looks nice! Yes those hangar mounts are a beotch to grind off! I would highly recommend gusseting those shock hoops (even with the frame plating)
slabcs
Yeah I was thinking about it.  I saw that tittiecrawler and Tallchevy both broke theirs off.  I don't know though... My 84 just has them straight up welded to the frame with no plating, and no gussets, and I've put them through hell for three years and they still look cherry.
Relentless
toyyota
It's no wonder your front axle bends, the Toyota engineers didn't plan for such rough treatment......
slabcs
Well it's been a while.  I've been working on this thing pretty much every day for a month straight.  Where to start?
I ordered some Cragar Soft 8's with custom backspacing to solve some rubbing issues I had.  The tires would hit the leaf packs when I turned and the rears would rub the frame pretty hard.  I went from a 17x8 4.5"BS to a 17x8 3"BS.
With new wheels it gave me an excuse to install the Staun internal beadlocks I had sitting in my garage for over 2 years.
New valve stems and internal valve stem hole drilled.
Now onto the big project.  Body and paint.  First to strip it down, those factory stripes were really growing on me.  It's a shame they had to go.
Making some room.
Another cut.
A small piece of metal was bent and tacked in to fill the gap all around.
Some filler pieces.
Grind it down and retack as necessary. Rinse and repeat.
Pulled out some warpage from welding.
Pulling more dents, bondo, putty, sanding, etc.
The other side.
Some dope rollers.
Topless.
Relentless
slabcs
Sanded down, taped up, time for some primer.
Primer
Guide coated.
Windshield was removed to fix some rust.
It was block sanded, then it went back to the booth for more primer, and more block sanding.  I'll spare you guys on those pictures though.
Then the doors and fenders came off, and it went back to the booth to get the jambs painted.
Mixing up some paint.
BMW Alpine White.
Blacked out core support and aprons, doors and fenders back on, wet sanded, bagged up again, ready for paint!
Relentless
slabcs
Hood taped up.
Taping the side.
BMW Black
A RIDICULOUS amount of work.
Relentless
slabcs
Here's some more from after I laid the clear down.
That's it for tonight.
Relentless
toyyota
Thank you for the Pictures! I know how much work you have done. It is beautiful!!!
LilChief87
looks sick bro nice job why the  stripes like that
slabcs
Quote from: rocktoy83 on August 17, 2008, 08:26:53 PM
that is one bad  :moon: paint job  :bowdown: looks  f :censored: ing good bro  :beerchug:
Thanks man.  I appreciate the feedback!
Quote from: toyyota on August 17, 2008, 08:30:40 PM
Couldn't have done it without your help, Dad.
Quote from: rebeltoy83 on August 17, 2008, 09:42:51 PM
I've had that idea in my head for a couple months, just wanted to do it so I did.
Relentless
NorCalToy
:willynilly:
looks fawesome dude! :thumbs:
i can only imagine all the work it took to get the spacing on those stripes to be equal... any tips on that? im gonna be doin a basic paint job soon but jus always wondered how people got those things so damn strait! but again dude. looks awesome!
:flamer: IFS
slabcs
Well it took more than 3 hours of taping per side.  Probably 7 hours of taping total.  It was tedious, and I felt like I was losing my mind.
Relentless
Jud
"bout tree fiddy"
joey0712
Is that the white runner that was in front of your house?
91 Toyota High pinions f&r.
sloyota
nice buildup man..you should call Chip Foose for a job.. :thumbs:
I'm not responsable for my own action's.
slabcs
Quote from: Jud on August 18, 2008, 12:25:38 AM
That :pokinit: is way PIMP!!!
Thanks man, yours is looking good too.  It looks like it came out nice and low.
Quote from: joey0712 on August 18, 2008, 08:32:48 AM
Yes, this would be it.
Quote from: sloyota on August 18, 2008, 08:56:37 AM
Haha, I think I'd go crazy if I had to do this for other people all the time.
Relentless
