Author Topic: Front drive shaft extension....  (Read 1513 times)
navydood
  • Turtle Points: -5
  • Male Posts: 17
  • Member since Oct '03
  • F/A-18 Jet Engine Mech
« on: Jul 09, 2004, 07:58:15 AM »
Marlin Crew...
If I extend the length of the front drive to equal the amount in length that I would lose from adding dual cases, and then buy the long slip from you, would the 8" of slip be enough for running 85 rears up front on 35's?
And no, I am not going to build a square shaft.  I don't want one.  Even if one was givin to me.
rockhound
  • Turtle Points: 169
  • Male Posts: 817
  • Member since Nov '03
Re: Front drive shaft extension....
« Reply #1 on: Jul 09, 2004, 10:13:42 PM »
If you account for the extra 2" that rears move the axle, sure.
I believe long slip is for the droop you get from soft springs. When you measure for driveshaft length, I think you measure from flange to flange.
Tire size doesn't come into the equation.
I'd run square without hesitation, if I didn't like 4 wheel dirt tracking so much.
« Last Edit: Jul 09, 2004, 10:20:11 PM by rockhound »
How you 'sposed to know what your limitations are, till you exceed them.
www.RunandPlayMotorsports.com
84runner
  • Turtle Points: 99
  • Member since Dec '02
« Reply #2 on: Jul 12, 2004, 03:02:11 PM »
The only real way to tell is meaure you droop and and 6 1/2 inches for the extra case, other wise it's an educated guess , but who knw how much droop your gonna bet until you flex it up.
Last post Jan 29, 2003, 12:09:54 PM
by BigMike
Last post Dec 29, 2004, 06:32:05 AM
by 4runner
Last post Mar 12, 2007, 07:42:05 AM
by MiniSimp
Last post Dec 10, 2007, 01:37:42 PM
by jtaco1
Last post Nov 19, 2008, 02:47:23 PM
by lax815
