what do you guys torque the leaf spring bolts and shackle bolts to?
ive always just put them on till the start to snug up to the bushings then stake the threads
OH OH another one "what do you torque Ubolts to?" answer "TIGHT"
man all these people wanting specs on things that just dont freekin matter
anyone know the torque spec of a muffler bearing?
To correctly answer this, we must define what a muffler bearing is. It is a recirculating ball type valve that opens when the engine is running and closes when it is not to prevent debris and small animals from entering the engine through the exhaust system. Some of them are sealed, and some are greaseable. If it's greaseable, you will see a zerk fitting somewhere on the muffler, usually on the top towards the front. Removal of the muffler may be nessecary to view the fitting. Otherwise, if it has no zerk fitting, it is sealed. If it's sealed, the torque spec is 22 1/3 in-lbs. If it's greaseable, it's as tight as you can go, then back off 1/4 turn. However, if you overtorque it, it may seize up, and when this happens, it's usually in the closed position, preventing your engine from running for more than a few seconds. When the bearing begins to go bad, it will usually make a tinny metallic rattling noise. If you hear this noise, take it to a certified mechanic immediately and insist that it is the muffler bearing and don't take no for an answer. The noise is most commonly misdiagnosed as a loose heat shield, and if left unchecked, can cause major damage to the engine and exhaust system.
I torque mine to 80ftlbs
Started by imaghost Project Research and Build-Ups
Started by imaghost Toyota Land Cruiser Tech
Started by NORCALRockwalker Parts For Sale
Started by heep70 Parts For Sale
Started by 86yoter Parts Wanted
