Total Members Voted: 91
x2...dont even waste your money joe.....they call them "tube kinkers" for a reason....although, i have seen some people use them with success...just not that often...I would imagine you would probably waste more steel on bad bends....steel aint cheap right now u know? You should be able to get a jd2 with a die for like 500(?)
dont expect to get even a 90* without the pipe collapsing
This is 100% true. I would venture you can go to 75-80* with some minor kinking only.
This is pretty darn close to a full 90.
I knew this was gonna be a juicy thread......
That is USA pipe too, don't expect that with import pipe.
The black kind.The key is to make sure the weld seam is on the inside of the bend and GO SLOW. You must have patience otherwise the pipe will flatten out on you.
Started by J.D.Zuki Parts For Sale
Started by 84runner Parts Wanted
Started by surfindave General 4WD Discussion
Started by mudadiction General 4WD Discussion
Started by 79yota4x Bumpers, Cages, and Tube Benders
