Total Members Voted: 91
You guys who are telling people to pack the tubing with sand..... have you done this yourself or just repeating a myth ? I would like to see some pics of tubing you bent with and without sand. I see people post this all the time, but have never seen anyone actually prove that it helps. Anyone got any first hand experience bending pipe with and without sand ? Any pics of both ?I've bent a lot of pipe with the HF bender with no sand and without heating the pipe. It has always worked well for me without kinking . Seems like the sand myth would be a lot of trouble for nothing.
If you are using pipe you don't need the sand, but you do w/mild tube.
This is a pipe bender with pipe size dies. If you bend something besides pipe with a pipe die, expect it to not work correctly. Mine makes a nice bend with the sch 40 pipe that it was designed for without using sand. I get what your saying about the sand, but don't blame the bender because you used the wrong size tubing. Also thinner wall will kink easier. I have a JD2 bender with a 1.750 die , 5.5" radius and if I bend 1.750 .093 wall (exhaust tube) with it it will have ripples in the bend. Bends 1.75 .120 wall perfectly though.
more pics please
Ok, so UnlcleJPL4x4.... did you ever bye a HF bender and if so what is your opinion?
You will have to use 1-5/" tube in the 1.5" die, to keep the bends relatively tight. The heavier the wall tube, the better the bends, avoid anything thinner than .125 wall tube.
Started by J.D.Zuki Parts For Sale
Started by 84runner Parts Wanted
Started by surfindave General 4WD Discussion
Started by mudadiction General 4WD Discussion
Started by 79yota4x Bumpers, Cages, and Tube Benders
