85 Red X, My son is now cancer free!!! Back to wheelin!
Started by Thomas P, April 13, 2008, 10:39:40 PM
I.D.G.A.F
Killer rig the wider stance is bad a$$ :thumbs:, have you broke a rear axle yet with the spool?
Thomas P
no i havent broken a rear axle, is it pretty common? i know a guy on the board who is runnin 33's on a runner and no locker and broke one. I have a spare shaft just in case
'14 Camry SE
SCX10 Honcho on roids!
I.D.G.A.F
I was just wondering bc I'm going with the spool in the rear with dual's & 38.5.
gotrocks
Quote from: I.D.G.A.F on December 18, 2008, 07:00:16 PM
I have wheeled with 40's, 37, 35 etc. and never broken a rear toyota shaft.  All of them have been locked up and I've wheeled in the rocks snow, mud and everything in between.  The only thing I've broken is a rear locker (lock rite) and a lot of front axles until I went to 30 spline longfields.
I.D.G.A.F
Hey Thomas, you think I can tuck 39.5s with just a 4in Marlin kit?
I know ill have to trim my fenders and what not... as well as BFH the firewall. lol
ill match the lift in the rear as well.
Thomas P
are you runnin any body lift? i would do the RUF's with a shackle lift up front, all you would need is some shackles since you would re use your rears, plus you would advance the axle forward, and keep those tires off your cab, you will have to add and subtract leaves to your liking, or you coul buy 4" marlin rears for the front and rear to get the axle forward, if your gonna run 39.5's you need that axle forward.... you could also re drill your spring perches to cheat another 1" or so
'14 Camry SE
no body lift.
I could run a 2in BL though easily.
the marlin springs move the axle forward already. so I think I am good on that.
but 39.5s will work on 4-5in lift and some firewall pounding and fender trimming? :D
Thomas P
i think it will be a close fit, id go with the 2" bl too
'14 Camry SE
thats what Ill do then :D
i can make one for under 20 bucks.
Thomas P
bl's also give you more room to get to other things, one very important advantage
'14 Camry SE
yota_krawler
yes it does! starter, altinator, radiator etc
Thomas P
starter went from being a huge ginormous pregnant dog to a walk in the park with my 3" BL
'14 Camry SE
yota_krawler
yota_krawler
yes it does!
the top trans bolts are another one!
and not have the AC pump in helps getting to the Starter, Oil Filter and Fuel Filter.
Thomas P
x2 on the tranny bolts they still suck but not so terribly
'14 Camry SE
i found out a new trick on getting to those.... through the shifter holes in the floorboard!
SO FREAKING EASY AND ITS STRAIGHT ON TO THE BOLTS!
use extensions and you can SIT in your seats and undo them with ease.
yota_krawler
yota_krawler
just a question, why did you post on rig gallery and not build ups?
Thomas P
haha i debated...... but i built my rig before i started a thread, so i didnt know what to do with it......
'14 Camry SE
yota_krawler
Thomas P
they are never done until they are done (rolled 50 times, caught on fire, and hauled to the wrecker) and even then some parts live on.........
'14 Camry SE
yota_krawler
Thomas P
so my new plans for the crawler, 1 ton chevy master, and rear discs
'14 Camry SE
yota_krawler
Thomas P
also tryin to get the 3/4" less drop than stock pitman arm
'14 Camry SE
yota_krawler
Thomas P
alright lets get some good wheelin in...... pics tomorrow fellas
'14 Camry SE
