Author Topic: wheel spacers?  (Read 2887 times)
93 toyota
  • Member since Dec '07
wheel spacers?
« on: Jan 27, 2008, 02:50:58 PM »
hey. im throwing a bracket lift onto my truck feb. vacation and i need to throw in some wheel spacers. i was just wondering what you guys thought of these ones from 4wheelparts. they look legit but i figured you guys would know the best.
http://www.4wheelparts.com/PDT295378.aspx
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
Re: wheel spacers?
« Reply #1 on: Jan 27, 2008, 03:17:17 PM »
if you use those, you are effectively shortening the amount of studs the lugnuts grip. if you use marlin, or all pro, or similar, they have another set of studs so that isnt an issue
93 toyota [OP]
Re: wheel spacers?
« Reply #2 on: Jan 27, 2008, 06:50:46 PM »
oh , i didn't know that marlin even made them . ill deffinitly go with marlins' kit then no doubt.
thanks
-drew
edit: all i need is about .25in. of space to clear the arm once its lifted. im running a 4inch backing right now and if i buy the 1.5 inch ones from marlin, would it be wayy too much. becuase that seems a little nuts to me.
« Last Edit: Jan 27, 2008, 07:03:13 PM by 93 toyota »
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: wheel spacers?
« Reply #3 on: Jan 27, 2008, 07:08:39 PM »
:rofl:   now if you need a 1/4 -3/4 inch  i can see using those
anything over 1 inch you need these
http://www.frontpagecart.com/app/netcart.asp?MerchantID=58912&ProductID=2088118
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: wheel spacers?
« Reply #4 on: Jan 27, 2008, 07:13:45 PM »
i would never use these... they are crap. talk to anyone in the tire industry about it... they are crap.. i have seen wheels fall off of cars because of those, and i have seen studs trashed because of those.... either get new wheels or get real spacers with their own studs. do not endanger yourself or others using the slip on crap
Hammerhead
  • Turtle Points: 100
  • Male Posts: 564
  • Member since Nov '04
  • Junkyard Dog
Re: wheel spacers?
« Reply #5 on: Jan 28, 2008, 01:58:20 AM »
I've been running the Marlin 1.5" spacers for years with no trouble whatsoever.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
DanS
  • Turtle Points: 5
  • Male Posts: 434
  • Member since May '06
Re: wheel spacers?
« Reply #6 on: Jan 29, 2008, 03:12:58 PM »
Yes X10, I've got 1.5" Marlins and torqued to 'Marlin' recommendations with no problems.
« Last Edit: Jan 29, 2008, 03:42:36 PM by DanS »
Wow, been looking at my 4Runner rust away too long, need some inspiration and here I will find it...!
85 Toyota 4Runner, solid axle, 22Re, original paint and graphics and not a straight panel to be found!
crawlerdan
  • Male Posts: 4,770
Re: wheel spacers?
« Reply #7 on: Jan 29, 2008, 03:37:22 PM »
ive run 1.5s, 2s, and 3s, with no issues, for about 8 years now on a few different rigs.
MAKE SURE YOU TORQUE THEM TO WHATEVER MARLIN SAYS, NOT TOYOTA SPECS!!!!!
bajamil
  • Male Posts: 76
  • Member since Feb '08
  • Jump it!
Re: wheel spacers?
« Reply #8 on: Feb 15, 2008, 10:40:43 PM »
did you have to use longer studs (pressed in studs that hold rotor on) to hold those those 1.5" ones in place?  because the MC kit has new studs that hold the wheels on but not longer studs for the rotors.  :flamer:
Bajamil!!!! and i quote, "If you speed up you will go FASTER!"
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
Re: wheel spacers?
« Reply #9 on: Feb 16, 2008, 12:16:06 AM »
Longer studs aren't needed. Use the supplied lug nuts to bolt the spacer to the hub. Use your lug nuts & bolts the wheel to the spacer. You now have 12 studs & lug nuts per wheel.
87 4Runner redo
83boytoy
  • Male Posts: 9
  • Member since Oct '06
Re: wheel spacers?
« Reply #10 on: Feb 16, 2008, 04:26:35 AM »
i have worked in the tire industry for 4 years at americas tire co. and have seen what can go wrong with running spacers and would suggest that if you need to gain some width that you never use a slip on spacer that just gives you less contact with the lugnut to stud.  for one you have less threads holding it on and the main cause for accidents is that you have decreased the strength of the stud and made it non hubsentric.  if you go with a product like marlin, allpro, or trail-gear  what you are doing is keeping it hubsentric, and with the added studs you arn't loosing any strength from the studs.  one of the biggest things is when you have the slip on spacer you are taking the contact point of the lugnut that is a cone shape and trying to tighten it to something that is now a flat piece and not recest to match the cone shape for a even distribution of weight causing the lugnut seat to move and loosin causing a wheel to fall off.  with the bolt on spacer they retain the same cone shape causing a uniform lugseat so that you have a strong grip and no chance of lossing a wheel as long as you recheck you lugnuts every now and then because the aluminum spacer will compress when you first install them making the lugnuts loosen.  the only fall back to bolt on spacers is that you increase stress on the factory studs slightly from increasing the leverage point of the tire.  i personally run 1.5" spacers on my truck and feel that there is no problem of running these and have never seen a problem with them as long as after 100miles of installing new spacers you retighten the lugnuts to 100ft lbs.  i hope this helps. ps sorry for the wording and spelling i have had a few to drink lol
bajamil
  • Male Posts: 76
  • Jump it!
Re: wheel spacers?
« Reply #11 on: Feb 16, 2008, 10:05:11 AM »
ok  :beer: sounds good after that... i just installed these 1.5 MC on the front, and the studs on the vehicle do not go all the way through the supplied nuts and honestly they look a little scary because those hold the wheel on now. the supplied lug nuts look like they go on about half way until they are tight, anybody else have this issue
Hammerhead
  • Male Posts: 564
  • Junkyard Dog
Re: wheel spacers?
« Reply #12 on: Feb 17, 2008, 07:14:34 PM »
I run 1.5 MC spacers on my Toy and they fit just fine.
'88 X-cab, V6
844x4
  • Male Posts: 134
  • Member since Sep '07
Re: wheel spacers?
« Reply #13 on: Feb 19, 2008, 05:32:52 PM »
I have seen this before too!  Anyone else have info on this??
I guess you could have longer studs pressed into your rotors and solve the problem.
It takes a long time to achieve "instant" success.
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
Re: wheel spacers?
« Reply #14 on: Feb 20, 2008, 10:45:54 AM »
Yes, get it fixed.  I believe marlin sold the correct lug nuts.
Kel3283
  • Male Posts: 12
  • "Born to Thrill"
Re: wheel spacers?
« Reply #15 on: Feb 21, 2008, 12:30:32 PM »
Don't mess up the threads, that's all I gotta say!
-KPF
Orowheeler
  • Male Posts: 29
  • yeah
Re: wheel spacers?
« Reply #16 on: Feb 21, 2008, 08:55:59 PM »
im looking for some wheel spacers
The Rooster
  • Male Posts: 48
  • *life's short and hard like a body building elf*
Re: wheel spacers?
« Reply #17 on: Feb 22, 2008, 06:50:23 PM »
..x2
It's A work in progress but it'll get there..slow and low im breakin er in easy...oh btw stock birfs suck!!!!
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
              -Ronald Reagan
Last post Nov 21, 2002, 04:21:02 AM
by cruzila
Last post Nov 27, 2002, 09:19:21 AM
by BigMike
Last post Jun 14, 2004, 09:46:45 AM
by 84runner
Last post Sep 24, 2004, 09:23:21 AM
by Bob Garrett
Last post Nov 03, 2004, 04:49:33 PM
by GrimReaper
