sheard off pinion in my 2005 powerstroke.
Started by ToYocRawleR, December 31, 2007, 05:49:35 PM
ToYocRawleR
Today i was trying to get out of a ditch and ended up snaping the pinion gear in the from axle.  My truck only has 40k on it.  Will waranty take care of this?
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
freds40
My guess would be no as the axle was probably bound up and the break was driver induced. But ya might as well ask, worst thing that can happen is they say no.
"between projects"
Duffil
I say no also, but try it.  The shop in front of my work has done one or two of those jobs. (Super Poopy with 35s, chipped and stock gears=BOOM)
Hottrod81
No, your warranty is done.  If you have an extended warranty, I doubt that they would cover it.
ToYocRawleR
Rigs:
ToYocRawleR
my truck only has 41k on it.  I thinkin the drivetrain still still cover till 100k
Rigs:
i would think so,  but tell them you were pulling your boat  out  of the  water  :shhh:
Thomas P
and put everything back to stock..............
'14 Camry SE
SCX10 Honcho on roids!
86bobbedtoy
Quote from: 79coyotefrg on January 01, 2008, 11:55:06 AM
Quote from: 1985efiyota on January 01, 2008, 01:07:01 PM
x2
Hottrod81
I don't think it covers axles.  It only covers the engine and I think maybe the transmission.
LOCKEDRUNNER
Factory warranty is for 3 years or 36,000 miles.The diesel warranty is 5 years or 100,000 miles with a $100.00 Ded. If your lifted and have oversized tires and have extended warranty the warranty company may send out a inspector. If not in stock condition they will not cover the repair.
MiniSimp
You never know until you try; I broke my front driveshaft wheelin in my Dakota on 35's took it back to the dealer (after I pressure washed the undercarraige), they fixed it for free!
FIREBALL
What size tires are you running? and did you have the hubs manually locked or were you using the switch inside only? Just curious because i've had my hubs unlock and lock again at times when just using the auto mode.
Hottrod81
Redbeard1
ford spelled backwards stands for.... driver returns on foot
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
ToYocRawleR
Totally forgot i posted this...any ways ford ended up paying for 70% of it.  I guess a carrier bearing failed and caused the diff to bind against the pinion and BAM, theres goes the pinion.  Cost me just under $500 ford payed around a grand and i kept the pinion gear.
Im totally stoked cause my truck has 35's on it with a chip, exhaust and intake.  I guess the dealer ship said none of that matters unless they tell ford and they didnt.
Rigs:
ToYocRawleR
Yea that was definitely nice of em, i think they kinda have their tail between their legs after the ordeal they;re in with international.  At least they;re not being hypocrites.
Rigs:
TheCookieMonster
ya...as long as they stand behind their product :yesnod:
LOL @ IFS
Quote from: ToYocRawleR on March 27, 2008, 03:00:50 PMIm totally stoked cause my truck has 35's on it with a chip, exhaust and intake.  I guess the dealer ship said none of that matters unless they tell ford and they didnt.
You might want to read this.  http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
