when the clutch is pressed? that is a pilot issue, not a throwout issue
Both bearings spin with the clutch pedal depressed. With the clutch pedal down the input shaft stops spinning as soon as you make a shift and the throwout bearing spins as long as it's against the clutch cover with your foot on the pedal (even slightly).
i know, but then why doesnt the throwout make noise the rest of the time?
Started by BLACKDOG « 1 2 » Engine
Started by don25 Engine
Started by wildchild1066 Toyota Pickup/4Runner Tech 1979-95
Started by 83MT Toyota Pickup/4Runner Tech 1979-95
Started by T-1000 Engine
