Author Topic: 1UZFE > A340F Bellhousing > Adapter > R151F = AX-15 Throwout bearing?  (Read 5302 times)
T-1000
  • Male Posts: 13
  • Member since Feb '09
Hey y'all,
I'm a newb with a tough problem...
Right now I have plans to mate a 1UZFE V8 to a A340F bellhousing (5.5"/165 mm deep), then an adapter plate (I have a CAD file ready, ~30 mm thick?) then a R151F trans.
Unfortunately, I'm having trouble sorting out the clutch actuation.
I know the R151F clutch will work with a modified 3GSTE flywheel, but I need to use a hydraulic throwout bearing since there won't be any cut outs for a fork.
The R series and the AX-15 share the same bolt pattern and inside diameter (1.125") in the front bearing retainer, but the outside diameters (which I cannot find anywhere) are different, as are the lengths between certain years. R151F is a 6.5"/165 mm input shaft, while the AX-15 is 7.875"/~200 mm.
What I need to know is the length of the bearing retainer for a pre-'92 AX-15 (the models that had a hydro throwout bearing) and it's outside diameter. And the throw length of the throwout bearing.
The same info on the R151F would be great too.  :gap:
This is pretty much the only thing holding up this swap because I don't want to buy a bunch of parts that won't fit together.
TIA. And pic below if you don't believe me.  :biggthumpup:
dniel
  • Male Posts: 194
Check out lextreme for the details I read a thread on there of someone doing this but I don,t remember all the details. I think they said the jeep bearing leaked alot and they weren 't that reliable. A couple were using an after market bearing I think it was from a company named howel  :dunno:.
I'm installing a 1uz also but I am using auto tranny. Are you doing a build thread?
1uz-fe, 1 tons, 44" tsl
Last post Mar 05, 2005, 10:06:09 PM
by assman
Last post Mar 22, 2005, 10:08:52 PM
by BLACKDOG
Last post Mar 20, 2005, 08:18:13 AM
by 79coyotefrg
Last post Mar 15, 2007, 08:15:43 PM
by RABIDYOTA
Last post Apr 04, 2024, 08:54:36 PM
by Pappy
