Busted the pinion gear when towing, need help
Started by *FFC*, December 14, 2007, 10:39:41 AM
*FFC*
I got a friend who has an '01 Chevy 1500 5.3L with a 6" lift.  He was towing and busted his pinion gear.  Only 2 teeth broke off, but he's wanting to go to a lower gear.  What's the recommended gear ratio for towing with 35" tires? I'm terrible with these things, so I told him I'd ask ya'll  :hammerhead:
Thanks in advance!
EDIT: :doh: :doh: :smack: It's a 5.3 not 4.3
Blingn
it is a chevy =bad :rofl: ,small motor=bad, 1/2 ton=bad
Mistaken
1997 gmc sierra short box 4x4
33"mastercraft MT's
cat back duals
olivedrab85
I had an 06 crew with a 5.3, I put in 4.56's and it towed my 4runner around good. Not sure about the 4.3 though
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
Gittinit
A semi float, six lug 14 bolt would be a great/cheap upgrade for that rig. That 6cyl would never break it.
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
*FFC*
Sorry guys, I'm an :idiot:
a 14 bolt upgrade? with what gears? keeping the 4:56's?
14 bolt is a chevy 2500 rear axle
i would go with 4.10's or 4.56's  cause he probably had  3.73's  if  not 3.37's
*FFC*
Quote from: 79coyotefrg on December 14, 2007, 04:02:32 PM
No, he had 4:56's that broke when he was towing.  He was thinking of either going with 4:10's or keeping what he's got, but he wanted to do it right, so I figured I'd check for him what 'right' is with a 35" tire.  Seems that the 4:56's are the required ratio.
freds40
My guess is he has the 4l60E auto. I'd say at least 4.56s to tow with that. That tranny and towing any decent load are not a great combo.
"between projects"
Mistaken
the 4l60e's are put into s-series trucks and the 1500's the beefier 4l80e is put in 2500 and 3500's.
the 4l60e's are a terrible transmission when it comes to towing. with out an aftermarket tranny cooler ran in series with the factory one the transmission is knowen to go over 250* when towing. with temps like that it does not take long for parts to fatigue from the heat and fail, i know from experiance. with the after market cooler my truck rans at a constant 120* when not towing. i would suggest your friend upgrade his tranny while he is under there
33"mastercraft MT's
cat back duals
He should slide a complete 2500 in there to be safe. A 1500 is pretty weak for towing, my Durango has a higher tow rating.
I'd swap out the whole axle to at least a 2500 to save having this issue again. Not only will it be stronger it will increase braking power
