PRACTICALLY ANYTHING YOU WANT (missouri)
Started by DTB, November 29, 2007, 04:03:48 PM
4runner freak
How much for a 1" bore master cylinder / dual diaphragm brake booster shipped to 80233
Thanks
BTW they came in most V6 '86-'89 trucks, 4runners, LC, and almost every Toyota after '89.(That I know of)
Finally got my '85 4runner!
Let the buildup begin!
Working on DUAL-TRANNYS
http://www.pirate4x4.com/forum/showthread.php?t=862345
squirrel84
chinkboy
BoG-ToY
THANKS FOR THE YOKE......SHOULD TURN OUT GOOD
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
46&2
Hey DTB I was just wondering if you have any 84-89 first gen 4runner/second gen pick up doors with the tan interior trim thats in good shape. I just need the interior trim and arm rests. If you have some and can give me an estimate on shipping to 95959 that would be sweet. Looking for some interior trim to finish up my half doors. Thanks man
fatkidskickrocks4x4
hey, thanks for the gauges. Great shipping!!
If you have to go "balls deep" you aren't doing it righ
DTB
BoG-ToY
HEY  DTB.....how much for an 89 pickup passenger tailight lense......drivers corner lense and 3rd gen pickup ubolts from the rear axle....  I'd need the ubolts and nuts...maybe washers too?    then all I gotta do is find me some springs for up front..... shipping would be KILLER on a set of stock front springs right?   I think Id just need ONE maybe
rockhound
Tuffy needs a couple interior door panels in grey.  '85. Also the rear carpet. Xtra-Cab.
How you 'sposed to know what your limitations are, till you exceed them.
www.RunandPlayMotorsports.com
How much for a power steering pulley shipped? The one I need is on the crank it is only held on to the crank by like 4 12mm bolts, and I need the bolts too.
ninja turtle
Quote from: Rocksurfer on July 05, 2008, 04:57:10 PM
bump
TxFireman
Got any 1st gen center latch tailgates? If so, shipping to 78253. Thanks.
82 Toyota SR5 SB 4WD stock w/ 30's
97 Chevy K1500 4" w/ 33's
89 Chevy K5 (Trail project, w/ a huge parts pile)
06 Hummer H3 stock w/ 33's
GJToyotabug
OK here's what I have-
84 Toyota 4runner
I need-
-5speed shifter knob
-brown bezel around the shifters with shift boot
-brown window crank both sides
-throttle return spring
and that's it for now
shipped to 81501 thanks
John Doe
cts198505
i need a passenger side door for a 1981. with or without the glass. i have the vent and the main window. got any???
GJToyotabug
Quote from: GJToyotabug on July 06, 2008, 10:03:48 PM
84 Toyota 4runner
I need-
still waiting for a pm need thease parts
fatkidskickrocks4x4
hey dtb how much for a dash mount off a second gen just the stuff to mount the dash i have the dash already
94runner
1994 4runner: toy axles, 37's, armor,
tacoguy
#410
how much for a new or used no rust if posable, fuel sending unit for an 88 toyota pickup 4wd and 6 to 12 wheel studs as well shipping to 62565
Shamb
DTB i'm looking for a clean dash pad out of an 82' Toyota
got anything let me know!
thx
GA Runner
89' 4Runner
Doof
46&2
any word on those brown interior door panels?
raptome
#416
DTB-I'm looking for parts for an 82 4x4 short bed;
passenger rear side marker light, no lens needed
1982 Toyota Pickup 4x4 Deluxe
Vortec_Cruiser
For a top shift xfer case, I need one or two hi-lo shift forks.
Email to [email protected]
Thanks -
Ed Gilbert - TLCA #5659, So. Cal. TLCA,
1977(reg. as 1962) FJ40 w/5.7L Vortec
Formula 4 Toy F006 (Build in-progress)
Doable
 Was stolen from truck looking for a Front driveshaft bolts and nuts  for an 1983 toyota truck.(This is for a buddy)
How about an 84-88 SR 5 Dash (instrument cluster)for an auto transmission  has the light on the top left for power / normal transmission , tach, oil, water temp, fuel gauge? zipcode 70582 Thanks Albert
Nothing puts a smlie on my face like the green glow of 4x4 on the dash !
BSLCA.com
ajordan1975
i need a FI rail and injectors for a 22re. PLEASE!
shipped to 77598
Thanks
Andy
